Seeking Advice First Router Project - Page 2 - Router Forums
 34Likes
post #11 of 68 (permalink) Old 01-22-2018, 12:13 AM
RainMan 2.0's Avatar
You don’t have to buy one ,as there easy to make , but this is what I’m referring too
Ok ,I never insulate
RainMan 2.0 is offline
post #12 of 68 (permalink) Old 01-22-2018, 01:27 AM
Tricky on a dome, Rick. How would you control the depth accurately? Again, not saying it can't be done, but i'd like to know it works first...
Rick's got the jig; I nominate Rick!
DaninVan is online now
post #13 of 68 (permalink) Old 01-22-2018, 02:05 AM Thread Starter
First Name: Jules
Originally Posted by RainMan 2.0 View Post
You donít have to buy one ,as there easy to make , but this is what Iím referring too
https://youtu.be/UkRh68OC_lM
Iíve actually got a jasper jig mate. Itís how to run it on flat surface seeing your working on a dome. Hence my comment about building a box around it flush to give a horizontal surface to anchor from
Sent from my iPhone using Tapatalk
DaninVan and Nickp like this.
hyped is offline
post #14 of 68 (permalink) Old 01-22-2018, 07:05 AM
Nickp's Avatar
First Name: Nick
Excellent idea to build a flat surface for it...box would be perfect...
Then a template for the circle and recess...trim router would be easier...Bosch Colt or Ridgid...
Rough cut with jig saw first...use your box for base for the saw...
Nick
Nickp is offline
post #15 of 68 (permalink) Old 01-22-2018, 07:11 AM Thread Starter
First Name: Jules
Cheers for feedback Nick. I think I might give that a go mate. Iíve got two extra bowls in case (well in the highly probable event I stuff one up)
Even if I hole saw out the first cut and then build a circle template for the recess
hyped is offline
post #16 of 68 (permalink) Old 01-22-2018, 07:14 AM
Nickp's Avatar
First Name: Nick
Use thin material for the top of the box so you don't need to over-extend the bit...
Nick
Nickp is offline
post #17 of 68 (permalink) Old 01-22-2018, 07:21 AM Thread Starter
First Name: Jules
Thanks for advice makes sense! Recess only needs to be like 4mm so assuming if I keep the thickness of template under say 6-7mm should be ok for most decent routers?
hyped is offline
post #18 of 68 (permalink) Old 01-22-2018, 07:23 AM
Nickp's Avatar
First Name: Nick
Some additional info...make sure you route in the correct direction...handheld would be left to right or clockwise in your case...maybe you know that already...
hyped likes this.
Nick
Nickp is offline
post #19 of 68 (permalink) Old 01-22-2018, 07:24 AM Thread Starter
First Name: Jules
I do now
Thanks nick?
hyped is offline
post #20 of 68 (permalink) Old 01-22-2018, 09:49 AM
First Name: Gary
I agree with Nick. Just make sure the bowl is secured (sandwiched) to the box well.
gmercer_48083 is offline
Seeking advice on where to position router on new table build bigrizz Table-mounted Routing 15 01-08-2018 08:56 PM
Newbie seeking advice on building a router table and how flat it needs to be bigrizz New Member Introductions 20 01-07-2018 01:55 AM
Seeking advice on Router Table AmitChattoraj Table-mounted Routing 6 01-21-2013 06:24 PM
