I知 at a loss as to how this is done - Router Forums
 24Likes
post #1 of 15 (permalink) Old 12-02-2018, 10:22 PM Thread Starter
RainMan 2.0's Avatar
Default I知 at a loss as to how this is done
I love the way the front corners have been sheered off on this DIY speaker enclosure , but have no idea how this would be done .
I can’t see how you could do this accurately with a belt sander . It would be to big and awkward for a bandsaw , well maybe if it was sitting in a jig ?
I could see a specialized router sled just for this job being attached maybe .
Any theories ?
artman60 likes this.
I don稚 always insulate , but when I do .
Ok ,I never insulate
RainMan 2.0 is online now
post #2 of 15 (permalink) Old 12-02-2018, 10:52 PM
jj777746's Avatar
Hi Rick,maybe it's done the old fashioned way with handsaw & plane then sanded to the chamfer edge lines with progressively finer sanding. Your finished speaker box looks more modern than the plain square item at the top. James.
TwoSkies57 likes this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #3 of 15 (permalink) Old 12-02-2018, 10:58 PM
Glue layers of material into the portions that will be cut away. This would not block the speaker openings, which do not appear to be extra thick. Then you could make the cuts with a table saw by using a taper jig for the sides, and for the top you just need to run the top back across the blade, while holding it against the fence. Any other shaping could be done with sanding. The front edges appear in the finished enclosure to have been sanded to produce a curve.
TenGees likes this.
DesertRatTom is online now
post #4 of 15 (permalink) Old 12-03-2018, 07:46 AM
mimac's Avatar
First Name: Brian
I think a track saw could easily do this
TenGees likes this.
mimac is online now
post #5 of 15 (permalink) Old 12-03-2018, 07:47 AM
TwoSkies57's Avatar
Judging by the amount of dust on the floor, alot of sanding was done...I'm thinking James pretty much got the right idea as to how it was done. What impress's me is the finish. DAMNNNN!!! I'd love to what that schedule consisted of.
Skipper the Penguin
TwoSkies57 is offline
post #6 of 15 (permalink) Old 12-03-2018, 09:59 AM
TenGees's Avatar
First Name: Paul
Very interesting how the face looks bent at the woofer.
TenGees is offline
post #7 of 15 (permalink) Old 12-03-2018, 10:09 AM
I'm guessing a two part gloss epoxy. My son who has been into making speakers for quite a few years now had me do a matte epoxy finish for him once. I used a cheap spray gun in case I couldn't clean it out.
I have a 6 x 108 vertical sander that might do the facets if I lowered the table way down and added a larger surface so that I could tip the box and still have it on the table. But hand sanding might be easier in the long run. Just mark the extents of the facets on face and edges and sand to the lines.
TwoSkies57 and jj777746 like this.
post #8 of 15 (permalink) Old 12-03-2018, 02:49 PM
Danman1957's Avatar
Is it possible that the parts were dry fitted, marked and then chamfered before final assembly ? That finish is amazing !
You can see the top was added and the different layers on the front on the second photo. I think with a tall fence the front could be done on a table saw and then sanded smooth.
Cherryville Chuck likes this.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #9 of 15 (permalink) Old 12-03-2018, 06:19 PM
TwoSkies57's Avatar
I was guessing an expoxy was at the root of things....Still an impressive application to say the least. Especially over a core like MDF. Reflections don't lie, this is one fine job.
jj777746 likes this.
Skipper the Penguin
post #10 of 15 (permalink) Old 12-03-2018, 09:23 PM Thread Starter
Regarding the finish . The builder was asked and replied that he took it to a body shop where they painted it .
I didn’t know those cuts were called facets ? I asked him how he cut the angles , but he hasn’t replied
TwoSkies57 and TenGees like this.
Hearing loss and the I-phone as a hearing aid JFPNCM Lobby 13 12-15-2015 03:27 PM
The loss of the slide show feature is a major problem TWheels Site Help and Suggestions 18 05-07-2015 01:55 PM
I知 about ready to take a sledge to my router!! JohnnyB60 General Routing 42 04-28-2012 03:05 PM
Avoiding the loss of tools allbarknobite Lobby 8 10-17-2011 01:34 AM
I知 such an idiot!! Nickbee Router Bits - Types and Usage 14 12-21-2008 09:16 AM
