Door frame repair - Page 2 - Router Forums
 22Likes
post #11 of 22 (permalink) Old 11-06-2019, 02:33 AM
From the picture, the house is looking old but the thing which surprises me a lot is that all the parts are in good condition. And this is really amazing.
HeatherWomac is offline
post #12 of 22 (permalink) Old 11-06-2019, 10:12 AM
JOAT's Avatar
First Name: Theo
Originally Posted by Tiny View Post
would you still like to see the progress of this and maby others too?
Most definitely indeed. Don't get to see stuff like this very often, especially in such detail.
JOAT is offline
post #13 of 22 (permalink) Old 11-12-2019, 04:38 AM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
My customer is still thinking of the colour so it was The right thing from me to do to just paint it white in september. Atleast the wood is seald and ready and The right colour is just a minor detalie.
The house is dated back to aproximently 1900. It was The head office to a mill that exported timber atleast to GB. It had about 100 employed.
The new doors are as old as the house. They are originaly from a mansion (must check The right word) on south Finland. I think it had burnt down because the paint looked like it.
Normaly our old houses lasts very well IF the roof is OK and the foundation is higher than 30cm/1'. The pine of which the houses were built from were slow grewn and old. They contain hartz that are consisted of different types of penisilin so it wont rot. Also the paint that was made of boiled linseedoil and lead was very good and prevented wood from getting wet but alowed it to dry after The rain.
marecat3, Stick486, old55 and 1 others like this.
Esko
My profession is to restore old loghouses that is in the classical way. Look at www.tiny-e.fi and (FB) Tiny-e. Restaurointipalvelut for exaples
Tiny is offline
post #14 of 22 (permalink) Old 11-12-2019, 04:46 AM
nice work Mr. Esko...
post #15 of 22 (permalink) Old 11-12-2019, 04:49 AM
can I ask how you flashed the sill???
post #16 of 22 (permalink) Old 11-12-2019, 11:54 AM
mimac's Avatar
First Name: Brian
Esko is the top coat of finish on the doors old varnish? If it is a quick stripper for old time varnish is lye (Sodium Hydroxide). You can usually buy it at the grocery store here under the brand name Gillets. Put a cupful(or 2 for a stronger solution) in a glass or stainless steel container (aluminium and plastic dissolve), add 4 cupfuls of water. Don't let it splash as it will burn you. Use safety glasses, rubber gloves and use outdoors or in a well ventilated area. Use a natural bristle brush as plastic based bristles will melt. Paint it on the item to be stripped and let it sit. Some times you can just hose the finish off. Works well on lead paints as well. My dad showed me this over 50 years ago ant the first time I used it was on a set of highly carved oak chairs. I didn't have to scrape any finish just hosed it off. It even bleached out the old stain back to natural white oak color. Just don't soak the wood with water for an extended time. If you try this do a small piece in an inconspicuous area first to see if it is going to do the job.
DaninVan and Herb Stoops like this.
mimac is online now
post #17 of 22 (permalink) Old 11-12-2019, 08:37 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
"can I ask how you flashed the sill???"
Please can you traanslate?
Esko
Tiny is offline
post #18 of 22 (permalink) Old 11-12-2019, 08:49 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Thanks Mimac for The hinta. Here Finland as a qualified restorer Im not alowed to use such metods. I can use heat while scraping The paint of but no chwmicals.
Esko
Tiny is offline
post #19 of 22 (permalink) Old 11-12-2019, 11:06 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Thanks Sticki ☺️
Esko
Tiny is offline
post #20 of 22 (permalink) Old 11-12-2019, 11:55 PM
