Door frame repair - Page 3 - Router Forums
 22Likes
post #21 of 22 (permalink) Old 11-13-2019, 03:42 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Ok Stick I try.
The door frame is constructed of two horisontal and two vertical parts and they are combined together with five finger joints on each corner. After removing the rot in such way Ill get flat bottom (to get a straight glue surface) I made each part complete that is hundreds of measurings to acheve an identical replacement. The most difficult thing was to get the horisontal part to fit the joints because the first steps are made of concrete
Hope this helped you some
Esko
My profession is to restore old loghouses that is in the classical way. Look at www.tiny-e.fi and (FB) Tiny-e. Restaurointipalvelut for exaples
Tiny is offline
post #22 of 22 (permalink) Old 11-13-2019, 04:21 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
I made as good copys as I could of the rotten Wood. Then I glued them
Esko
Tiny is offline
