Rescued lids. - Router Forums
 19Likes
  • 17 Post By papasombre
  • 1 Post By CharleyL
  • 1 Post By papasombre
post #1 of 7 (permalink) Old 12-29-2019, 02:21 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Default Rescued lids.
Hi, guys.
I have been at home for six months in a row so I am doing any home repair that I can. In this case the pictures will tell the story.
We, woodworkers are everywhere!!!
papasombre is offline
post #2 of 7 (permalink) Old 12-29-2019, 05:49 PM
JOAT's Avatar
First Name: Theo
Cool.
JOAT is offline
post #3 of 7 (permalink) Old 12-29-2019, 06:41 PM
CharleyL's Avatar
First Name: Charley
Only trouble with using those T nuts is that they are designed to be used with the points facing the load point, not away from it like the way that you are using them. You might get more holding power if they are glued into the knob, but I would have put the T nut into the hole in the cap with the points facing toward you. Then screwed a bolt of the correct size into the T nut and coated it's threads with a thin layer of grease to keep the epoxy from sticking to it. Then fill the hole around the bolt, covering the T nut with epoxy and filling the cap hole. When the epoxy dries, if you have completely coated all of the affected area of the bolt threads with grease, the bolt should unscrew, leaving a very strong threaded hole for you to attach the knob to whatever needs it.
If you epoxied the T nut in place in your knob it might hold, but it won't be nearly as strong as if you installed it the other way.
This is a great way to make knobs from old bottle caps, if you can get the epoxy and the T nuts easily, but my way should prove to be considerably stronger.
Charley
papasombre likes this.
Central North Carolina
CharleyL is online now
post #4 of 7 (permalink) Old 12-30-2019, 12:37 AM
The Hobbyist's Avatar
First Name: Joe
Charley
Yeah ... I was trying to figure out why it stuck me in the eye like that, but you are right. Tightening the screw will not pull the knob against the lid. It will pull the T-nut out of the knob.
Joe
http://www.aguyintown.com
Retirement is overrated.
The Hobbyist is offline
post #5 of 7 (permalink) Old 12-30-2019, 08:05 AM
MYB
First Name: Mark
Nice use of those caps. Enjoy your drink while you are waiting for the next one.
MYB is offline
post #6 of 7 (permalink) Old 12-30-2019, 09:02 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Charley.
I'll take into consideration your advice for the next time. Thank a lot for the input.
CharleyL likes this.
post #7 of 7 (permalink) Old 12-30-2019, 09:28 AM
First Name: Joe
Ah, I see that he used epoxy to hold the fitting into the knob. That should work okay.
Joe
