Camera/Lens Landscapers Box - Router Forums
 21Likes
post #1 of 12 (permalink) Old 01-09-2020, 07:32 PM Thread Starter
Bstrom's Avatar
First Name: Brian
Default Camera/Lens Landscapers Box
In the past, I never could bring enough camera gear on trips to the Smokies for landscape and Astro trips, so decided to make a box that would carrry most of my lenses along with four camera bodies for maximum choices in composition in the field. Kinda went overboard as the whole kit loaded up weighs over 30 lbs. but it fits in the car well and leaves little at home to miss or forget.
It was as much a dado exercise and short of nailing each joint perfectly they all lined up squarely, etc. Each bin is lined with a thin firm foam lining from J-Ann’s fabric shop - the red pockets are for the cameras.
kp91, jw2170, CharleyL and 15 others like this.
Common Man Woodworking
Powell, TN
Bstrom is online now
post #2 of 12 (permalink) Old 01-10-2020, 07:32 AM
sreilly's Avatar
First Name: Steve
Astro trips eh? Through the telescope or time exposures through lenses? 99.9% of my images are all taken using a telescope mounted CCD camera.
MT Stringer likes this.
sreilly is offline
post #3 of 12 (permalink) Old 01-10-2020, 08:26 AM Thread Starter
Bstrom's Avatar
First Name: Brian
I use mirrorless cameras and have real limitations on focal length as a result but am taking ‘landscape’ Astro pix, not telescope shots, which would be great fun to do.
Powell, TN
post #4 of 12 (permalink) Old 01-12-2020, 07:11 PM
CharleyL's Avatar
First Name: Charley
I like the project, but if I was putting all of my camera gear in that, I would have a lid on it that held everything secure and in place, but could be opened/removed easily when the point of use was reached. Highway trips are frequently not as smooth as expected, and I would not want my thousands of dollars worth of camera gear flying round the inside of the car. I would also not want it easy for someone to see all of that gear through the car window when I made a rest stop, as it might be too tempting for someone. A secured lid could solve both problems.
Charley
jw2170 likes this.
Central North Carolina
CharleyL is offline
post #5 of 12 (permalink) Old 01-12-2020, 08:57 PM Thread Starter
Bstrom's Avatar
First Name: Brian
Charley
I gave that a lot of thought in the design stage. A solid ‘lid’ would be cumbersome to store in the car and the foam inserts do a fine job with any jostling since the cubicles are fairly close fitting.
However, I will look into a fine mesh ‘spider’ to secure those pieces just in case. Thanks for your observations.
Powell, TN
post #6 of 12 (permalink) Old 02-05-2020, 06:30 AM
eh?
elizzaparker is offline
post #7 of 12 (permalink) Old 02-05-2020, 06:45 AM
Knothead47's Avatar
Hmm. Don't have that much camera gear. That is a great idea and will b e of service for many years. Last Christmas, my wife gave me a backpack that holds all my gear plus what is included in a new camera on the to-buy list in the near future.
BTW, I live in SE TN, about two hours from the GSMNP. PM when you will be in the area and we'll see about getting together. I'm a freelancer.
John T.
Knothead47 is offline
post #8 of 12 (permalink) Old 02-05-2020, 08:11 AM Thread Starter
Bstrom's Avatar
First Name: Brian
I'm neither able or willing to 'backpack' cameras in the wild at my age. I usually shoot out of my car which is what this contraption was made for. From there I will mount a body/ens of a CF tripod and trek a little bit. Lazy, I know...
I'm north of Knoxville and go into the GSNP via Maryville to ride the river road to Gatlinburg - or turn right at the visitor Center and hit Cades Cove - or take 441 to Newfound Gap and Clingman's Dome. Don't hike much but will take a short walk at times.
Powell, TN
post #9 of 12 (permalink) Old 02-05-2020, 09:12 AM
RainMan 2.0's Avatar
Nice setup Brian , and a great way to keep stuff well organized
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 12 (permalink) Old 02-05-2020, 11:44 AM
A canvas cover secured on one side, and with velcro on the other would do. And you can have the canvas stamped with some sort of message that would deter theft. for example, the words, caution, radioactive materials, keep cover in place.. That would deter most people.
RainMan 2.0 likes this.
DesertRatTom is online now
