Raised Panel Doors - Router Forums
post #1 of 5 (permalink) Old 11-30-2009, 11:11 AM Thread Starter
First Name: Merv
Default Raised Panel Doors
I am making my first raised panel doors. Do I need to use spacers (such as barrels or balls) between the panel and the frame? What benefit would these spacers be?
I have made a few test doors and find the panel fits firmly in the groove. Is that normal? How much of a gap should there be between the edges of the panel and the groove in the frame?
Thanks for your help.
Merv
myoung is offline
post #2 of 5 (permalink) Old 11-30-2009, 01:03 PM
Hi Merv
Yes, you should use them all the time, on all 4 sides,( gap, 1/16" to 1/8" the norm) wood is always on the move they may be tight now but in time they will become free floating so to to speak you can make your own with some thin weather stripping and a real sharp razor knife..I just hate the round ball type I'm always trying to find them all over the floor..
I use the ones below most of the time
http://www.sommerfeldtools.com/200ct...ductinfo/PNL1/
http://www.sommerfeldtools.com/1000c...ductinfo/PNL3/
Merv
post #3 of 5 (permalink) Old 11-30-2009, 09:59 PM
I size my center panel 1/4" total smaller than the rails & stiles ends up with 1/8" per side & use the Sommerfeld strips 2 per side, that's 8 per panel.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 5 (permalink) Old 12-01-2009, 07:49 AM
First Name: Danny
I didn't have any balls or strips one time and found a way to make my own. I got a tube of silicone, and cut the tip at the smallest setting then squeezed a small bead out on a peice of melamine; let it dry peeled it off then used it in the grooves.
Worked great, now thats what I do all the time, except I now use a mylar sheet to squeeze it onto. (doesn't stick)
jd99 is offline
post #5 of 5 (permalink) Old 12-15-2009, 02:53 AM
RLFX's Avatar
First Name: Randy
Great Idea !!
RLFX is offline
What size Router for making raised panel doors? TRN_Diesel General Routing 16 04-17-2010 05:37 AM
Raised panel, narrow doors amalgamator Router Bits - Types and Usage 3 11-17-2009 09:18 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
raised panel doors coupe General Routing 17 03-05-2009 10:17 PM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
