Dryer not heating? Check the power wiring. - Router Forums
post #1 of 12 (permalink) Old 01-06-2010, 10:49 AM Thread Starter
AxlMyk's Avatar
Default Dryer not heating? Check the power wiring.
The electric dryer stopped heating. So I dragged it away from the wall, after unplugging it, and took the back off. Checked the wiring diagram and proceeded to trace the problem. All the switches and high temps checked ok.
Put the back on and plugged it in. Turned the breaker on and tried it. Heat! Great, I fixed it.
Pushed it back to the wall and connected the exhaust hose and cable, and told Wifey it was ok.
She did a load of laundry, put it in the dryer, no heat. Well ding dang it.
Slept on it one night and thought to check the 240 volts.
Opened the breaker box by the dryer plug and got 120 on one leg. OK, problem found. Proceeded to check the breaker connections and things started to fall apart. Literally. The connectors were all cooked. It was a fire waiting to happen.
Since I had it connected to another breaker in the main panel, I ran the wire directly to the plug. Dryer works now, safely.
AxlMyk is offline
post #2 of 12 (permalink) Old 01-06-2010, 12:44 PM
dustmaker's Avatar
First Name: Frank
Mike, you are a fortunate soul to have found this before the impending disaster! A friend of mine just lost his storage shed to a fire caused by faulting wiring.
- Frank
Woodworking is more than a hobby.
It is a journey of discovery,
An application of innovation and creativity,
And an opportunity at self improvement.
dustmaker is offline
post #3 of 12 (permalink) Old 01-07-2010, 12:20 AM
CanuckGal's Avatar
First Name: Deb
All I'm gonna say is YIKES!!!
Good catch!
I measured, I marked, I cut.
CanuckGal is offline
post #4 of 12 (permalink) Old 01-07-2010, 04:23 AM
Nice pickup Mike,
Do you guys in US normally find it a problem running two voltages in the house wiring?
We only have to worry about 240v here in Australia?
jw2170 is offline
post #5 of 12 (permalink) Old 01-07-2010, 06:08 AM
Cassandra's Avatar
First Name: Cassandra
Hi James:
Running two voltages in the house wiring is not a significant issue. Most loads are set up for the 120V voltage and plug into the usual sockets. A few loads (e.g. stove, clothes dryer, and workshop loads) have a different socket or are direct wired. Distribution panels (breaker panels) are designed to facilitate the dual system.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #6 of 12 (permalink) Old 01-07-2010, 07:00 AM Thread Starter
AxlMyk's Avatar
James;
If we only had 240 volts, there would be too many stupid people electrocuting themselves.
AxlMyk is offline
post #7 of 12 (permalink) Old 01-07-2010, 01:39 PM
First Name: Joe
James,
Any 240 Volt line can be broken down to two 120 Volt lines. The problem here, in the USA, is that we are running at 60 cycles (OOps, showing my age); I mean 60 Hertz. If we converted to 240/50 all the TV manufacturers would love it, since none of our older TVs would work right (NTSC thing)
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline
post #8 of 12 (permalink) Old 01-07-2010, 07:10 PM
Cassandra's Avatar
Originally Posted by cbsjoez1935 View Post
James,
Joe Z.
Hi Joe:
With regards to modern day TVs, there is little likelihood that LCD, Plasma or LED set could care less about the input line frequency. Add in the HD or ATSC system and line frequency becomes even less important.
Now, all those clocks, motor loads and other frequency-dependent devices would be a problem. Decades ago (1950s, I think), Canada switched from 25 cycles to 60 cycles (that's before we got to Hertz), and all the motors had to be converted.
My father's clock in the living room was given to my parents by the hydro commission, to replace the old 25-cycle clock. Darn thing just keeps on going around -- over 50 years of reliable service!
Cassandra
post #9 of 12 (permalink) Old 01-07-2010, 07:51 PM
James;
Mike, I would not like to try it, but 110 probably kicks like a mule, 240 kicks like a mustang......
Both will hurt if they hit you in the head...LOL
Are you suggesting that 110 volt is safer if you cross the poles?
jw2170 is offline
post #10 of 12 (permalink) Old 01-07-2010, 10:30 PM
BigJimAK's Avatar
The way US single-phase 240VAC works is that each pole is 120V to neutral (ground). They are just 180* out of phase so, if you measure the voltage between the two hots, you get 240VAC. With a 4-wire circuit (2 hots, 1 neutral, 1 ground) like you see in stoves, the device has both 120VAc and 240VAC available.
BigJimAK is offline
Power! istracpsboss Lobby 4 10-26-2008 10:14 AM
