DIY Base Plate and Table - Router Forums
post #1 of 8 (permalink) Old 01-11-2010, 09:53 AM Thread Starter
Default DIY Base Plate and Table
Thanks for having me!
I've been researching a lot and I'm going to build my own router table shortly. I'm planning to use an old glass table stand (minus the glass) for the base because it's light weight and I have to carry it into the garage. I'm going to build the table top separately and clamp or screw it to the base when I use it. The table top will be laminated with a hard wood trim around the edges. I'm going to install an outlet on the trim so I can plug in the router and hit a switch when I'm ready instead of reaching under the table.
Does anyone have any suggestions? I'm happy to hear any thoughts.
I made a base plate last night. I bought a universal Freud base plate but intend to return it today, haha. I clamped the Freud base plate to a 1/4" plastic cutting board and used a flush trim bit to trace the cutting board to the size of the base plate. After making some precise cuts and drilling some holes with spade bits I had my own "Freud" base plate.
I bought the cutting board and some new spade bits and still saved $50 rather than spending $70 on the Freud base plate.
bcskinz is offline
post #2 of 8 (permalink) Old 01-11-2010, 09:53 AM Thread Starter
I'll post photos of my router table when it's complete. Wish me luck.
bcskinz is offline
post #3 of 8 (permalink) Old 01-11-2010, 10:07 AM
Noob's Avatar
First Name: Paulo
Welcome to the forum. Take a look at the many great router tables in the thread below and you might find some ideas for your own table.
Wanted! pictures of your table! LINK
Noob is offline
post #4 of 8 (permalink) Old 01-11-2010, 10:51 AM Thread Starter
Thanks for the link. There are lots of good looking tables on that thread. I just decided I'm going to use pins to mount my table top to the base stand.
bcskinz is offline
post #5 of 8 (permalink) Old 01-11-2010, 03:58 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Blake, and welcome to the RouterForums. Glad you are a member of our community.
Dave
the "Doctor"
Dr.Zook is offline
post #6 of 8 (permalink) Old 02-13-2010, 10:08 AM
First Name: Larry
Send a message via MSN to Larry Strawson
Hi Blake
Welcome to the community. Feels good to be able to reuse some items. You will find with use though that sometimes heavier is better than lighter. Your own use will tell you this. If your stand is too light and wants to move around while using you might want to add weight.
Larry
Larry Strawson is offline
post #7 of 8 (permalink) Old 03-24-2010, 09:47 AM
First Name: Swallow
Send a message via MSN to Swallow Send a message via Yahoo to Swallow
Oooo I do so like your use of the Freud router base, Yeppers a man after me own heart.
Retirement is easy, but You really have to work at it.
Swallow is offline
post #8 of 8 (permalink) Old 03-25-2010, 10:32 AM
CanuckGal's Avatar
First Name: Deb
Blake your setup sounds similar to the Oak Park router table. They use a dowel construction method to make the base and attach the top. It's a very simple but extremely effective set up.
I measured, I marked, I cut.
CanuckGal is offline
Mounting Router Base to Table Plate ccmnova Table-mounted Routing 5 12-02-2009 07:10 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
