Refinishing old door - need help - Router Forums
post #1 of 3 (permalink) Old 06-28-2010, 07:30 AM Thread Starter
dustmaker's Avatar
First Name: Frank
Default Refinishing old door - need help
Our front door is starting to show its age and I started yesterday afternoon to strip it down for refinishing. I have a detail sander that is making short work of the flat areas and getting into all the corners, but my question is how to sand down the "raised panel" areas and the molding around the crystal glass (oval shaped). I can do this by hand, but with temps in the 90's I am looking for a more efficient approach that won't destroy too much of the profile. Any help or suggestions will be greatly appreciated. Thanks.
- Frank
Woodworking is more than a hobby.
It is a journey of discovery,
An application of innovation and creativity,
And an opportunity at self improvement.
dustmaker is offline
post #2 of 3 (permalink) Old 06-28-2010, 02:17 PM
dutchman 46's Avatar
First Name: Howard
How about a chemical striper? What hind of door, metal, or wood?
John 3:16
dutchman 46 is offline
post #3 of 3 (permalink) Old 06-28-2010, 02:39 PM Thread Starter
dustmaker's Avatar
First Name: Frank
It's a solid oak door, no veneer, so it can take the sanding. It was also previously stained, so I am trying to sand all that out to try to get a nice even finish (again)...I don't think a chemical stripper will remove the stain as well, but I do thank you for the reply.
I am currently leaning toward a sanding sponge or maybe break out the dremel. There are a few attachments for the detail sander that I should also give a try. Anyway I look at it, it looks like a long tedious job...but those are usually the most rewarding.
I'll probably stop by one of the BORGS and have a look around unless someone chimes in with a better idea...
- Frank
cedar walls need refinishing eileen New Member Introductions 5 04-21-2010 09:32 AM
refinishing help cofboard The Finishing Touch 5 11-16-2009 12:12 PM
refinishing a table top bobi The Finishing Touch 2 10-11-2008 02:18 PM
refinishing a table top bobi The Finishing Touch 0 10-11-2008 12:47 PM
30 year old mahogany plywood cupboards need refinishing Sask Jack The Finishing Touch 3 04-03-2008 09:45 AM
