"sleeper floor" - Router Forums
post #1 of 7 (permalink) Old 08-08-2010, 06:12 AM Thread Starter
Default "sleeper floor"
We took up the concrete bed in the front entry and now want to lay new 16x16 travertine. We need to build the floor up and someone has suggested to use a sleeper floor.
1. When I look online to research most projects using the sleeper floor involve concrete slabs and trying to avoid moisture problems that occur if you try to combine wood and cement. Why would I use this option rather that just layering more wood on top of my old sub floor?
2. If I do use this method, how important is it to get the strips directly over the floor joist? Would I be redistributing weight to an unsupported part of the floor if my strips of wood don't sit on top of the floor joists?
3. Do I use adhesive to attach these strips or do I nail them into the floor joist below?
4. Since my floor won't be solid...there will be an empty space between my old subfloor and the new sheets I use to build up the floor....won't my floor have some bounce to it? It doesn't seem like it will be stiff enough to support my tiles...won't they crack?
Any thoughts would be greatly appreciated.
jhutchison is offline
post #2 of 7 (permalink) Old 08-08-2010, 06:49 AM
allthunbs's Avatar
First Name: Ron
Hi Jhutchison:
I have to assume that this is sitting on the main deck of the house and that the front entry was "carved out" of the surface of the main deck. How much are you trying to build up? How thick is your prep work (i.e. self-leveling concrete base for the new tile)
Structure:
1. how deep and long are the floor joists under the front entryway?
2. are there cross-braces between the joists?
3. what are the centres for the joists?
4. how thick is the sub-floor?
5. take your 400lb line backer teen-aged son out to the front entry with you. Stand there and have him jump up and down. If you can feel him jump, your floor isn't strong enough to support Aunt Martha on your new tile floor. Time to beef it up. Alternatively, I had a little 15lb. Shih-tsu-Poddle mixed race dog that just walked at a pace that set up complimentary vibrations and when he walked you could feel him all over the house.
It is quite possible that you will need to return to the concrete bed that you so painstakingly took up. You have several issues: moisture that will come on snowy and rainy days; adequate support for your tiles even during dry periods where your structural wood is going to shrink slightly; The structure will have to be protected from that. The floor was that was there, how badly was it cracked? That will tell all. How thick was the concrete? If there was no cracks, the original builder knew what he was doing and you want to replicate what he did.
Depending on how the floor is built, very important. see above.
I would use adhesive and galvanized/stainless screws not nails.
Yup! Your supporting structure must be designed to support the new tile floor. It may be worth your while to sister in supplemental joists between existing ones if there's too much bounce. My thinking is this: if there is any bounce put in cross braces. If there's still bounce, go back and either sister in new joists or space new ones between the old ones.
Let me explain. I had a house with a crawl space. The joists were 24" on centre and were 2 x 8s 12' long with a 1 1/2" notch taken out of each end. I ended up sistering in several joists to support ones that had split and supporting them with joist hangers. I then went back and put in bracing between each pair of joists and my floor went from a trampoline to strong and solid in a week's work.
Pictures would help too. Got sketchup? try giving us a drawing so we have a good idea of what you're trying to accomplish.
Allthunbs
allthunbs is offline
post #3 of 7 (permalink) Old 08-08-2010, 07:20 AM Thread Starter
Yes, my entry way is a carve out and it is approx 3" below the subfloors of adjacent rooms.
Thank you so much for your response. I don't know the answer to the rest of your questions, but will be down measuring in the basement today so I can get back to you. Really appreciate the time you took to respond. I am totally an amateur, but want to make sure the job is done right.
post #4 of 7 (permalink) Old 08-08-2010, 08:05 AM
tdublyou's Avatar
First Name: Tim
Ron is spot on with his advice. It sounds to me as though you are going to want to go back in with a mud job, i.e. what you had before. The only way I would use a sleeper system in this instance would be if I were putting in a hardwood floor.
Tim
"The difficult we do immediately... The impossible takes a little longer" - Grandpa
Don't worry about nothin', aint nothin' gonna turn out right anyway" - Dad
tdublyou is offline
post #5 of 7 (permalink) Old 08-08-2010, 10:03 AM
allthunbs's Avatar
First Name: Ron
Ok, you have to understand something.
I'm not a contractor or a carpenter. I had problems with the floors in all of the homes I've owned. I'll make a comment but I'll rely on others to corroborate or refute any statements I make. You have to remember, advice is worth what you pay for it. Note above, that I had to make a bunch of assumptions without really knowing your situation. The more information you give all of us, the easier it is to guide you.
Allthunbs
post #6 of 7 (permalink) Old 08-08-2010, 02:52 PM
tdublyou's Avatar
First Name: Tim
Ron,
I am a carpenter/contractor by training though I am no longer practicing for profit. Your advice on this was fairly accurate based on the information available.
I am familiar with the type of floor construction that was removed and for a new travertine floor, I would suggest a new mud base. However, if the original poster, (I wish people would at least include their first name in their profiles), doesn't want to do that much work, satisfactory results could be achieved by building up the sub-floor with plywood, glued and screwed to the floor joist and each successive layer, with a top layer of Durock set in thin-set and screwed with the appropriate fasteners. you want at least 1" of solid plywood under the Durock. If space allows, you could fur up the floor with sleepers to save on plywood. If sleepers are used, they should run perpendicular to the joists and be screwed to them. If the sub-floor is substantial enough you can screw to it as well, just don't use too long of a screw.
Tim
tdublyou is offline
post #7 of 7 (permalink) Old 08-08-2010, 03:42 PM
allthunbs's Avatar
First Name: Ron
Hi Tim:
Originally Posted by tdublyou View Post
Ron,
I fear that lack of effort may not the case here. I think he merely lacks experience. A fate all of us have suffered over time. We'll have to await his research.
Allthunbs
