dissimilar metals - engineers pls help - Router Forums
post #1 of 6 (permalink) Old 08-16-2010, 01:31 PM Thread Starter
allthunbs's Avatar
First Name: Ron
Default dissimilar metals - engineers pls help
I remember that stainless steel screws and steel don't mix in damp environments. However, I can't remember if aluminum and steel also suffer dissimilar metal characteristics. I'm trying to rebuild the bottom of my patio door and I need to refasten the tracks. The screws were completely gone.
Thanks for the help
Allthunbs
allthunbs is offline
post #2 of 6 (permalink) Old 08-16-2010, 02:07 PM
RJM60's Avatar
First Name: Robert
Thanks for the help
Stainless steel screws in an aluminum frame should be fine. Aluminum is so active (anodically) that it will form a protective oxide coating in minutes. Stainless steel is also rendered realatively inactive through passivation. Stainless steel fasteners in aluminum is a commonly used system.
RJM60 is offline
post #3 of 6 (permalink) Old 08-16-2010, 04:21 PM Thread Starter
allthunbs's Avatar
First Name: Ron
Thanks very much RJM. Stainless in Aluminum it is then.
Allthunbs
post #4 of 6 (permalink) Old 08-16-2010, 06:12 PM
RStaron's Avatar
First Name: Ron
I agree with RJM60. Stainless fasteners in Alum. is the way to go.
A person can never have too many tools!
RStaron is offline
post #5 of 6 (permalink) Old 08-25-2010, 02:10 PM
Default Galvanic
Hi Ron,
Galvanic bi metalic corrosion can occur between stainless steel and aluminium, ref nobility table.
On aircraft construction for instance a barrier is made between the two surfaces if disimilar metals are to be in contact.......
However as it's only the patio door it;s not likely to experience speeds of mach 2!!!!!
I wouldn't worry about it.
Shortcut is offline
post #6 of 6 (permalink) Old 10-05-2010, 06:03 PM
First Name: Thrifty
Thanks for the help
Try Brass screws
Thrifty Tool Guy is offline
