Workshop heaters - Router Forums
post #1 of 4 (permalink) Old 08-25-2010, 02:26 PM Thread Starter
Default Workshop heaters
I have a small fan heater which I use in the home.
It's 3 kw and cost arrd $60, works fine in the home.
I have also used it in the workshop during winter.
As winter rears it's head, I am considering purchasing an industrial 3kw heater...that's the max we can plug in and go inside our home and garage systems in the UK without a separate line being installed.
So why are the same kw heaters coming in at 160$ to $200?
They have the same output, are a little larger, they are mass produced in China.....so is it just the fan size that heats up a larger area faster?
ohh and are they a good investment????
M
Shortcut is offline
post #2 of 4 (permalink) Old 08-25-2010, 03:06 PM
BigJimAK's Avatar
M,
Assuming the heater is an "electrical resistance" type (vs. a heat pump or electronic ignition for some other fuel), a 3kW heater will put out about 10,240 BTUs whether its a residential model, commercial or industrial model. While the industrial unit may have a larger fan that dissipates the heat more, to actual heat should be the same. Why the difference? Let's consider a 1500 watt blow driers, for drying one's hair.
Here in Alaska you can buy a cheapie for about $10. That unit will be very noisy and likely give off a wee bit of burning smell as it is used. It has cheap, poorly made bushings and a cheaply made fan for cooling the motor and blowing the air. It's a disposable unit and if it lasts you two years using it once a day (100 times), you replace it.
The barber / hair stylist cuts perhaps 15 heads of hair a day. At that rate the cheap dryer would last about a week, so they buy a commercial model that sells for perhaps $100 or so. This fan likely has well made, sealed bushings and a reasonably-made fan. It also likely carries enough air that you don't get the burning smell. It lasts perhaps 1-2 years being used 15 times per day.
Then there's the industrial heater. It might still be 1,500 watts but is used 24 hours per day, 36 days a year. When it fails the assembly line its in must be shut down until it is replaced. This heater likely has sealed ball bearings and moves enough air to ensure no internal burning. It is likely thermally insulated so the outside of the heater doesn't get hot enough to burn a worker. It likely has a timer circuit that lets the fan run for a bit after the heater is turned off, to cool the insides. This unit is likely designed to be able to go 12 months or more without maintenance (or at least minimal maintenance) and may last 2 - 5 years, and cost $500 - $1,000.
In your home heater, what you should expect to be buying is quality of components and life expectancy. What you actually get will depend upon the vendor. What's right for you depends upon your needs, wants and of course, willingness to pay.
BigJimAK is offline
post #3 of 4 (permalink) Old 08-30-2010, 01:42 PM Thread Starter
Thankyou moderators
It just goes to show that you care aout the forum members....and thank's for the reply
M
Shortcut is offline
post #4 of 4 (permalink) Old 08-30-2010, 11:13 PM
BigJimAK's Avatar
You're welcome... and thank you...
BigJimAK is offline
Safely heating a basement workshop rm&co Shop Safety 4 06-28-2010 05:39 AM
By popular demand... the Router Workshop Mike Site Help and Suggestions 6 12-17-2008 09:53 PM
**New** Router Workshop Series 500 DVD - Available Now!! Mark Site Help and Suggestions 9 08-05-2007 05:07 AM
