Carport supports need replacing - Router Forums
post #1 of 5 (permalink) Old 09-07-2010, 08:18 PM Thread Starter
Default Carport supports need replacing
I've a double space carport attached to my house. It has 6 supports along the perimeter. The supports are I beams made of 2 steel square tubes with decorative elements welded between them (trellis?). They are probably 30-40 years old, are really rusted near cement and the front bent this winter (previous owner ran into with car and bent back into shape - almost - so figure metal fatigue here).
I would like the have them replaced - but not sure what with. Will pressure treated 4x4 posts be adequate for the load (+ Virginia snow - really unexpectedly heavy this year) or 4x6 posts - or should I just head directly to steal posts?
Jim
jmoore65 is offline
post #2 of 5 (permalink) Old 09-08-2010, 08:42 PM
Jim,
Recently constructed a carport. You may find that local code requires 6 X 6 columns with concrete piers. PA where I live requires a minimum of 24" deep piers but, in the works are a 30" requirment (now law in states like NJ where codes are pretty strict). VA may be different. My carport was about 24 feet long, the piers are approximately 7.5 feet apart. The local home center or lumber yard could give you the skinny. In our township, the zoning & building inspector poke their noses into the project & start recommending ridiculous add-ons that are not required by national or local code. Hope this helps.
Nockmoi is offline
post #3 of 5 (permalink) Old 09-08-2010, 09:34 PM
kp91's Avatar
First Name: Doug
Jim,
My addition sits on 6 x 6 columns, per code in Spotsy, VA. Since it straddles our driveway, the columns are protected by concrete filled 4" pipe sections to shield them from 'bad' drivers.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 5 (permalink) Old 09-08-2010, 09:41 PM
Bargains Finder
First Name: Tommy
Find a steel fabrication shop and have them weld up some 6 inch steel tube piping with flats on the end and have them drilled for 4 screw holes. Should be stronger than any wood beam supports out there and you can case around it to make it as decorative as you like.
Tommyt654 is offline
post #5 of 5 (permalink) Old 09-08-2010, 10:11 PM
Hi Jim
I would go with the 4 x 6 post they can support tons, you can dress them up a little bit once they are in place with some poplar wrap, some white paint and your done if they get damage you can replace them easy..I would suggest using some of the new Flex (plastic) stock( decking stock 1 x 6 ) and make your own 4 x 6 post, that way they will not rot out and they will last forever, some carr. bolts and your set.
Jim
Rolling cabinet supports Glenmore Special Needs Woodworking 22 11-21-2012 05:25 AM
Replacing the worm gear on the Triton Router Jack Kremeier General Routing 3 06-23-2010 04:15 AM
tip for cheap home made pipe clamp bench supports italian biker Jigs and Fixtures 7 06-15-2010 09:44 AM
replacing a worn pulley ferd Tools and Woodworking 7 11-23-2009 09:15 AM
Replacing rockler dovetail bits gazingm42 Router Bits - Types and Usage 1 10-10-2009 09:00 PM
