Three way switch problem - Router Forums
post #1 of 14 (permalink) Old 10-05-2010, 06:08 PM Thread Starter
First Name: Thrifty
Default Three way switch problem
Hello,
I've completed the wiring on a three way switch set-up for my shop and the switches do work in proper sequence, but the lights are really dim. The circuit is limited to lights, but is downstream of a GFI receptacle. Any thoughts?
Thanks,
TTG
Thrifty Tool Guy is offline
post #2 of 14 (permalink) Old 10-05-2010, 08:20 PM
kp91's Avatar
First Name: Doug
In the intrest of full disclosure, my electrical experience is primarily with 1 and 3 phase ungrounded marine electrical systems. Sometimes it takes me a bit to switch back to household wiring.
First off, what is on the circuit? In my limited experience with GFCI receptacles, I think that you would want your lights to be on the LINE side of the GFCI. I would hate for you to be in the shop and have your lights go out if the GFCI tripped.
Are the lights fluorescent or incandescent? If you've got a voltage drop, you may not be able to get some of the energy efficient ballasts to kick on. One of my former ships (now razor blades) had 106v on the lighting circuit. Only the big, old ballasts would excite the light bulbs. But I digress.
That being said, either the GFCI or something in your wiring is preventing the lamps from seeing the full 120vac. If you can, move the lights to the line side of the GFCI, this should eliminate it as the problem. If that doesn't work, check your wiring. Attached is a page with a bunch of different wiring diagrams for 3 way circuits.
As always, make sure every thing is isolated before you start poking around in it, and if you're uncomfortable with what you're doing seek professional advice.
Hopefully, Cassandra will see this post, she's usually got the answers for electrical stuff.
Installing A 3-way Switch With Wiring Diagrams - The Home Improvement Web Directory
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 14 (permalink) Old 10-05-2010, 08:52 PM
First Name: Von
TTG,
Have you checked to be sure you have the lights wired up in parallel. If you have them wired in series, they will be very dim.
Unscrew one of the lights, if the other light goes out, they are wired in series.
Von Bickley is offline
post #4 of 14 (permalink) Old 10-05-2010, 09:12 PM
Cassandra's Avatar
First Name: Cassandra
Yes, Doug, I did see the post and will reply.
Von's suggestion is the first one that came to my mind. It should be the first test you do.
Press the Test button on the GFCI, to trip the GFCI. The lights should go out if they are indeed wired downstream of the GFCI>
Another possibility is that lights are not properly wired between live and neutral. Is it possible that the lamps are wired from live to ground instead? Of course, this should trip the GFCI if the lamps are downstream of the GFCI. (A good ground should still light the lamps -- so if the lamps are live-to-ground and dim, then you have a ground problem also.)
Doug is right on not connecting the lights to the load side of the GFCI. In fact, lights should not be on the same circuit as receptacles.
Can you do a wiring diagram of the circuit that you wired? There are different ways to do a three-way circuit and I would need to know which way you chose.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #5 of 14 (permalink) Old 10-05-2010, 09:16 PM
Cassandra's Avatar
One nasty thought occurred to me after my previous post. Hopefully the lamps are not wired neutral to ground. If they are and they are glowing at all, then you have a serious ground or neutral problem!
Cassandra
post #6 of 14 (permalink) Old 10-06-2010, 04:34 AM
dutchman 46's Avatar
First Name: Howard
One thing that can help is to wear some rubber gloves. It will help if there is any stray power in the system. of course, disconnect the power. Check the ground system. make sure that You have no bad connections, It can cause electrical hazards from other circuits.
John 3:16
dutchman 46 is offline
post #7 of 14 (permalink) Old 10-06-2010, 06:49 AM Thread Starter
First Name: Thrifty
Default Thanks for the info....Parallel vs serial
Hello,
I really appreciate the information and I think the problem might be parallel and series circuits.......I have both. I've attached a diagram of the circuit with the dim lights (A and D). Lights B and C aren't connected at the moment, but there is current at the wire ends when the single switches are closed. Closing and opening the single pole switches has no effect on the brightness of lights A and D.
What is the correct circuit? Your input is appreciated
TTG
Name:	Current circuit.jpg
post #8 of 14 (permalink) Old 10-06-2010, 07:42 AM Thread Starter
First Name: Thrifty
Default Is this the proper circuit?
Hello,
Is the following circuit viable?
Thanks,
TTG
Name:	Parallel light circuit.jpg
post #9 of 14 (permalink) Old 10-06-2010, 07:53 AM
First Name: Ron
Originally Posted by Thrifty Tool Guy View Post
Hello,
Thanks,
TTG
The second one will work. In the first you have parallel and series connection to the lamps. They will be dim. Lamps need to be in parallel.
rweerstra is offline
post #10 of 14 (permalink) Old 10-06-2010, 08:19 AM
First Name: del
Hello,
Thanks,
TTG
Got a volt meter??? measure the voltage at the 2 light wire's . You should have aprox 120 volt's. Probly around 60 volt now ? could be wired in serries some how. Or you don't have a ground. Do a complete look around. You should be on the right side on the GFI but that wouldn't dorp voltage down. Just do a complete redo. Not that hard to do. Good luck
del schisler
port st. lucie, florida
del schisler is offline
Triton Router switch problem Gleneil General Routing 21 07-23-2018 09:28 AM
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Bosch Router Switch Problem bill kay General Routing 41 11-19-2010 08:29 AM
***Urgent*** Switch problem uzzaljss Lobby 1 07-16-2009 11:27 AM
***Urgent*** Switch problem uzzaljss Lobby 7 07-13-2009 04:20 PM
