Routeing ends of cut Lamanent Flooring - Router Forums
post #1 of 3 (permalink) Old 10-22-2010, 09:27 PM Thread Starter
Default Routeing ends of cut Lamanent Flooring
I have some nice lengh lamanent flooring and would like to find to find the proper routeing bits to make them usable. It is a locking floor system.Not sure if i can post product name here.
jackwit is offline
post #2 of 3 (permalink) Old 10-24-2010, 09:00 PM Thread Starter
Default I think this post would be better in the right forum
jackwit is offline
post #3 of 3 (permalink) Old 10-24-2010, 10:06 PM
kp91's Avatar
First Name: Doug
Jackwit,
are you trying to put the locking tongue and groove on pieces that have been cut? I don't know if those are available, I assume they are manufacturer specific. I know what you're talking about, I've had a lot of left over planks that I wish I could use.
If you wanted to try anything, you could find the smallest slot cutting router bit and make your own tongue and groove joint, but it wouldn't be self locking. Back to using glue like on the original pergo.
http://www.amanatool.com/bits-fv/45663.html these bits are for the solid hardwood type
1 John 1:9
Fredericksburg, VA
kp91 is online now
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Weatherwatch. derek willis Table-mounted Routing 11 02-14-2009 03:41 AM
5 Tips When Choosing Hardwood Flooring John_smith Project Plans and How To 0 10-17-2008 06:19 AM
Up Cut... Down Cut... Joe Lyddon Router Bits - Types and Usage 2 09-10-2006 06:21 PM
