hole in enamal coated steel sink - Router Forums
post #1 of 4 (permalink) Old 11-05-2010, 01:34 PM Thread Starter
gav
Country: Croatia
First Name: Gavin
Default hole in enamal coated steel sink
Desperate last minute question before I go to where the internet dare not roam.
I have an enamel coated stainless steel kitchen sink which came with no hole for the tap(faucet?). For uncoated stainless steel, I know I can buy a tool that is like a small press that cuts the hole, but I have heard that if I try this with the enameled sink, the enamel will crack around the hole.
So, anyone know the correct method for this ?
gav is offline
post #2 of 4 (permalink) Old 11-05-2010, 02:17 PM
Hi
If you have a GOOD hole saw it will do it and it will not crack/chip off the coating..but you must take care with the heat ,some dry ice will take care of that error...
post #3 of 4 (permalink) Old 11-05-2010, 04:10 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Gav
You've probably done it by now, but in case you haven't, try building a little circular dam outside the hole limits using kids' modelling clay. Try using cheap cooking oil as a combined coolant and lubricant, together with a hole saw running on the slowest speed you can manage. The dam should stop the oil running away while you are cutting.
Yes, the metal hole cutters that are two part, with a wavy edged cutting edge, that tighten with a bolt through the middle, are likely to chip the enamel, as they distort the metal as they cut.
Cheers
Peter
istracpsboss is offline
post #4 of 4 (permalink) Old 11-05-2010, 06:54 PM
Like Peter said this type is a no no.
Hydraulic Punch Driver Kit
Laundry Sink Project TRN_Diesel Show N' Tell 15 03-22-2009 12:01 PM
Laundry Sink Project TRN_Diesel Show N' Tell 2 03-09-2009 12:28 PM
counter top sink hole cabinet guy New Member Introductions 2 05-01-2008 09:49 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 07:57 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 04:29 PM
