Help finding 8" drawer slides - Router Forums
post #1 of 11 (permalink) Old 01-02-2011, 08:18 AM Thread Starter
First Name: pascal
Default Help finding 8" drawer slides
We decided to put our desktop PC in a nook of the living room for occasional use, unfortunately there is little space, so i had to go "low profile". The drawer shelf is intended to go a few inches below the upper shelf and will have the same outer contour so that there are two identical lines when the drawer is closed.
in my newbie ways i was overanxious to get to building and failed to locate a drawer slide before hand. I was hoping to put a detent out slide on here for the keyboard tray.
The top is 11" deep. The supporting sides have 8 3/4" available depth.
I have found exactly (1) 8" drawer slide, not a detent out.
any suggestions on where I can locate a drawer slide of how to make one?
thanks!
blurry is offline
post #2 of 11 (permalink) Old 01-02-2011, 12:30 PM
thanks!
Hi Pascal - Looks like a good candidate for sliding dovetails for drawer slides
John Schaben
jschaben is offline
post #3 of 11 (permalink) Old 01-02-2011, 01:24 PM
Hi
Many have errors trying to use the sliding dovetails but a T & G works very well and is a easy way to get the job done..
Or
You can just a buy a lift and lock setup from Rockler..
post #4 of 11 (permalink) Old 01-02-2011, 02:20 PM Thread Starter
First Name: pascal
wow, I had to google the dovetail slide - that is slick! not sure I'm ready to tackle that yet! I'm going to check around some more for an 8" slilde kit Starting to think I should have gone center under drawer slide. kind-off hard now that the desk is together...
blurry is offline
post #5 of 11 (permalink) Old 01-03-2011, 03:18 AM
Mike Wingate's Avatar
First Name: mike
Can you cut down a longer slide? Sliding dovetails are no problem with a router table and fence. Use a straight bit to hog out the waste then use the dovetail bit to cut the dovetails.
Mike Wingate is offline
post #6 of 11 (permalink) Old 01-03-2011, 06:58 AM
LexB's Avatar
First Name: Lex
Woodworker's Hardware has 8-inch full-extension ball bearing slides: KV 4100 series, and their economy full-extension slide is 9 3/4-inches long. There may other slides there to choose from, but I have to get back to work now.
LexB is offline
post #7 of 11 (permalink) Old 01-03-2011, 08:25 AM
First Name: mike
A couple of photos of a double dovetail with the Incra Ultra jig.
post #8 of 11 (permalink) Old 01-03-2011, 09:59 AM
Hi Mike
Did you know it can be done with the OP 3/8" spacer jigs, don't need a high end fixture to get the job done...done for peanuts with the OP jig and it's always dead on.
Spacer Fence - Oak-Park.com
post #9 of 11 (permalink) Old 01-03-2011, 10:09 AM
First Name: mike
Bob, It's just what I had close to hand. A 2 minute job, but dimensions were not that critical.
post #10 of 11 (permalink) Old 01-03-2011, 10:17 AM Thread Starter
First Name: pascal
Love those dovetail slides. I'll have to work on building some down the road. For now I just put in an upper and lower rail to slide on. The rails are removable which will allow replacement with and under drawer dovetail slide down the road
Thanks for the help!
blurry is offline
Garage Overall for Shop TRN_Diesel Workshop Showroom 558 10-24-2010 02:44 PM
Blummotion drawer slides... Brian Oglow Lobby 11 10-08-2010 01:33 AM
hinges and drawer slides rh111 Starting Off 16 09-29-2006 11:21 PM
EZ Link DougO New Member Introductions 2 03-09-2006 12:52 PM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 10:20 AM
