Doorway Transitions - Router Forums
post #1 of 4 (permalink) Old 02-02-2011, 11:54 AM Thread Starter
Ira
First Name: Ira
Default Doorway Transitions
I have to install a doorway transition which includes a sliding (pocket door). The transition is from carpet to hardwood and the heihgt difference between the top of the hardwood floor and the carpet pad is 1/4". The Hardwood floor height from framed under floor is 1/2". There must be clearance for the door to close. Are there pre-made transition pieces that I can buy? If not, I would appreciate any tips on making them or modifying baught ones, and installation tips as well. Ira.
Ira is offline
post #2 of 4 (permalink) Old 02-02-2011, 01:49 PM
kp91's Avatar
First Name: Doug
http://www.routerforums.com/introduc...tions-etc.html
Ira,
there are a bunch of different types that can be bought at the HD and Lowes, or you can use any hardwood. The thread above shows some fat ones I made, I've also made some more traditional looking ones, I can try to take a picture of later.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 4 (permalink) Old 02-02-2011, 09:39 PM
kp91's Avatar
First Name: Doug
Default recycled wood transitions
Here's a couple of pictures of an offcut from one of the other transitions I did. This is for a hard floor to carped.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 4 (permalink) Old 02-03-2011, 09:00 AM Thread Starter
Ira
First Name: Ira
Thanks Doug. This was helpful. I have been researching the best way to terminate the carpet so that there is no trip edge. I am going to first try using a carpet ramp to achieve equal level with hardwood floor and then kick on to tackstripping and tuck into the beaded gap. If that doesn't work out, I will use what you have shown me. Thanks, Ira.....Oh yeah...1Jn1:9.
Ira is offline
shape suggestions for transitions etc. mtnmaniac General Routing 3 08-25-2010 12:17 AM
Doorway Transition T-Moulding leftistelf Router Bits - Types and Usage 1 05-27-2008 09:04 AM
