Disassembling a kitchen cabinet - Router Forums
post #1 of 10 (permalink) Old 03-30-2011, 01:57 PM Thread Starter
First Name: Doug
Default Disassembling a kitchen cabinet
I read with interest the post regarding kitchen cabinet doors. I have the same problem with a refrigerator that is too tall for the cabinet. I need to take apart the cabinet and make it shorter. It is at least 35 years old, oak frame. Since I haven't found any cabinet makers interested in so small a job I must tackle it myself. Any tips or suggestions for getting it apart without destroying pieces of wood?
dshepord is offline
post #2 of 10 (permalink) Old 03-30-2011, 06:10 PM
Little more information would help. How tall is to tall? If we're thinking of the same thread, I think much of the problem was resolved by screwing the refrigerator feet in more. For half an inch or so, should be able to work around tearing the cabinet apart. 4 or 5 inches is another matter.
John Schaben
jschaben is offline
post #3 of 10 (permalink) Old 03-30-2011, 06:28 PM
Hi Doug
Sometimes it's best to just replace the cabinet after all it's just a box with door(s) that you can make easy.
post #4 of 10 (permalink) Old 03-30-2011, 06:46 PM
woodjoiner's Avatar
First Name: Leon
Hi Doug
Bob, that sounds just like a statement a builder would make when you are trying to bid a job.
You learn by doing, so I've learned. It's only a suggestion, It's not law.
If I said something let me know, good or bad.
woodjoiner is offline
post #5 of 10 (permalink) Old 03-30-2011, 06:50 PM
Hi Leon
Well yes and no, most short cuts just don't work out right like they say junk in junk out..if it's worth doing it's worth doing it right I think..
post #6 of 10 (permalink) Old 03-31-2011, 03:53 PM
First Name: K33F
cut a hole in the ceiling and put the top of the cabinet through the hole. Tell your wife its a design feature.
keeflester is offline
post #7 of 10 (permalink) Old 03-31-2011, 03:57 PM
First Name: K33F
or you could do what I did. Cut the top off the cabinet, trim down from the top. If the hinge is compromised, cut a new hinge hole, the only raw edges will be at the top out of sight. It worked fine in our kitchen.
post #8 of 10 (permalink) Old 03-31-2011, 05:03 PM
BigJimAK's Avatar
Ya get good air circulation in the cabinet to boot!!
BigJimAK is offline
post #9 of 10 (permalink) Old 03-31-2011, 05:15 PM
some cabinet makers cut the face frames so they hang down lower than the bottom of the cabinet by 1/4-1/2", and on cabinets 35+ years old the face frame may have been only nailed on with a few finish nails, of course since we dont know how tall the fridge is, or how low your cabinet hangs we cant really know what the best fix is
jcr3 is offline
post #10 of 10 (permalink) Old 04-04-2011, 02:23 PM Thread Starter
First Name: Doug
I should have been more specific. I need to reduce the cabinet by about 5 inches and I need a top on which to place things.
dshepord is offline
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 32 03-24-2013 03:26 PM
Routing out raised panel from kitchen cabinet door pacchiraku Starting Off 3 01-30-2011 10:28 AM
Disassembly of kitchen cabinet doors in order to make them smaller Thelma1 DIY and Renovation 7 01-15-2011 10:37 PM
Kitchen Cabinet for garbage cans. crfurnishing Show N' Tell 8 05-13-2009 02:00 PM
how to get all my kitchen cabinet doors all the same hight taylormaid General Routing 7 02-25-2009 11:52 PM
