Workbench ???? - Router Forums
post #1 of 9 (permalink) Old 04-05-2011, 08:39 PM Thread Starter
papawd's Avatar
First Name: warren
Default Workbench ????
I am considering one more worktable in shop. My old ones where built with plywood tops coated with polyurethane (5) coats . I am considering this one to be with a MDF top ...My question is what would be a good protective coating to put on this, or what would be a good choice for a clean workbench top???
papawd is offline
post #2 of 9 (permalink) Old 04-05-2011, 08:52 PM
Hi
My best one is 3ea. 3/4" x 4' x 8' MDF with 1/4" thick safety glass on top of that, it make it a snap to clean up glue ..or anything else..
post #3 of 9 (permalink) Old 04-05-2011, 09:58 PM Thread Starter
papawd's Avatar
First Name: warren
Sounds nice did not think of that and I have a freind with a glass company...Is the glass glued,screwed or bolted onto the mdf... I am kinda of leary of screwing the mdf as it may come apart and weeken....
papawd is offline
post #4 of 9 (permalink) Old 04-05-2011, 10:25 PM
Hi warren
No need to screw the glass down the mass will keep it place, the MDF has a screws in the corners but that's it, the mass will do the same thing, I'm not to sure how much the total weight it is but it takes two floor jacks to move it around ..if you use 1/2" thick glass it would be better, I have replace the glass once but I have tons of glass in the other garage, out of a bank front..
post #5 of 9 (permalink) Old 04-06-2011, 09:06 PM Thread Starter
papawd's Avatar
First Name: warren
Thanks Bob sounds like a good idea
papawd is offline
post #6 of 9 (permalink) Old 04-07-2011, 09:15 PM
N'awlins77's Avatar
First Name: Lee
Mines made of 2x6's, and about 5 coats of polyurethane. Then I have a piece of 3/8 pexi-glass for flatness, painting, glueing and such. It's only 2 ft deep though, and against a wall. So when I need more I have a 3x6x3/4 ply I put on saw horses. I picked up these realy cheap, and cheap looking plastic saw horses at Harbor freight, for 12 bucks each. They really look flemsy. But, at the store, I leaned my 216 pound body on it pretty good, and got no flex from the legs. I couldn't believe it. They are super light and fold and take up almost no room. With both open, and a sheet of 3/4 ply over it, it's pretty darn sturdy too. Might be a little short for those of you (probably MOST of you) of normal height.
N'awlins77 is offline
post #7 of 9 (permalink) Old 04-08-2011, 07:34 PM
RLFX's Avatar
First Name: Randy
Put 3/4" oak all the way around the table up the thickness of the glass that will keep it in place !
Table Saw: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.I cut that board 3 times and it's still too short!
RLFX is offline
post #8 of 9 (permalink) Old 04-09-2011, 11:15 AM
Noob's Avatar
First Name: Paulo
Hi warren
Each 4'x8' sheet of 3/4" MDF weighs 96 pounds, so that's almost 300 pounds not including the rest of the frame/structure.
Noob is offline
post #9 of 9 (permalink) Old 04-09-2011, 09:56 PM Thread Starter
papawd's Avatar
First Name: warren
Thanks for all the advice and help
papawd is offline
Workbench / Router table Jusaquikie Table-mounted Routing 14 03-15-2011 10:19 AM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 02:54 PM
Workbench Pictures -Sam- Show N' Tell 22 09-16-2009 07:11 PM
My new workbench kartracer63 Show N' Tell 9 03-25-2009 01:14 PM
Workbench I Microsuffer Microsuffer's Follies 8 03-16-2009 11:46 AM
