Exterior French doors weather sealing - Router Forums
post #1 of 10 (permalink) Old 04-11-2011, 01:40 AM Thread Starter
First Name: Roger
Default Exterior French doors weather sealing
I am designing a pair of french doors and would like to know the best way of sealing the join between the doors. I want to have them open outwards.
As I see it there are two options - rebate the doors or have them square but with a cover plate on the door which opens first.
The doors face northwards and are not likely to be exposed to too much weather as the rain producing fronts come from the south and west.
Rogercam is offline
post #2 of 10 (permalink) Old 04-11-2011, 03:16 AM
derek willis's Avatar
First Name: Derek
Default French doors.
In my past experience I think you will find that it will be better if you rebate the doors together, I would also rout in a weather strip into the meeting stiles as french doors can warp and allow very fierce draughts into the room. Good luck with your project.
Derek
derek willis is offline
post #3 of 10 (permalink) Old 04-11-2011, 03:30 AM
G’day Roger
Welcome to the router forum.
Thank you for joining us
I agree with Derek.
Sydney, Australia
jw2170 is offline
post #4 of 10 (permalink) Old 04-11-2011, 08:07 AM Thread Starter
First Name: Roger
Thanks Derek and James, I will let you know how I get on.
Roger
Rogercam is offline
post #5 of 10 (permalink) Old 04-11-2011, 11:27 AM
Hi Roger, Welcome.
My french doors have an astragal on the outside covering the gap. It has weatherstripping to seal the door gap. My doors open in. I'm sure you could do the same thing on out swinging doors. If you don't like the look of an astragal you could machine this interlocking step into the door edge as long as you have enough room for your hardware.
http://en.wikipedia.org/wiki/Astragal
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #6 of 10 (permalink) Old 04-12-2011, 04:07 AM
First Name: Derek
Here are a pair that I made a few years ago, they open out into my conservatory.
Derek
post #7 of 10 (permalink) Old 04-18-2011, 02:47 AM Thread Starter
First Name: Roger
Nice job Derek, I can clearly see the rebate.
Roger
Rogercam is offline
post #8 of 10 (permalink) Old 11-09-2011, 09:15 PM
Country: China
Although i don't konw the design of french door, i think you are right.
skywin is offline
post #9 of 10 (permalink) Old 11-18-2011, 10:44 AM
Country: Sweden
First Name: mauro
here in sweden where obviously the insulation is very important we cut on the frame of the door all around a kerf with a table saw or a shaper and after we snap in a sealing strip,between the door there is more o less 1 cm of reveal that will be covered by a moulding.i hope i helped you
maurosnickare is offline
post #10 of 10 (permalink) Old 10-05-2013, 11:57 AM
Originally Posted by jw2170 View Post
G’day Roger
I agree with Derek.
my name is paul i'm from buffalo ny usa
p58paul is offline
Bathroom cupboard doors locoboy Show N' Tell 6 01-19-2012 11:47 AM
Doors, doors and more doors! mailee Show N' Tell 2 03-16-2011 09:01 PM
Making french doors on a cupboard MrsOkee DIY and Renovation 9 01-08-2011 04:57 PM
French Doors & Mullions - Router Bit? FrenchDoor Router Bits - Types and Usage 20 10-09-2009 09:04 AM
