What's the easiest way of fastening the base of a storage cabinet to concrete floor? - Router Forums
post #1 of 5 (permalink) Old 04-26-2011, 10:41 AM Thread Starter
First Name: Doug
Default What's the easiest way of fastening the base of a storage cabinet to concrete floor?
I've used concrete nails in the past, but don't like them. How about Liquid Nails?
Thanks....
dbrode1 is offline
post #2 of 5 (permalink) Old 04-26-2011, 11:02 AM
I've used liquid nails to keep base cabinets from sliding around & it has worked fine.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 5 (permalink) Old 04-26-2011, 01:30 PM
BrianS's Avatar
First Name: Brian
Thanks....
If you are not going to move the cabinet, I would suggest Tapcon Concrete Screws, and I've also used Household Goop to glue smaller items to concrete.
Brian
(Origin uncertain)
BrianS is offline
post #4 of 5 (permalink) Old 04-26-2011, 01:59 PM
Is you cabinet against the wall? If so just fasten to wall with a few screws thru the nail rail. The weight will keep it from moving so no fastening to floor would be needed.
Whittier, CA.
jlord is offline
post #5 of 5 (permalink) Old 04-26-2011, 03:09 PM
Hi
I will 2nd James .
Most concrete floors are not flat and it's just about always high at the wall,just shim the cabinet and put in a screw or two into the wall stud should keep the cabinet in place and the toe kick should support the cabinet..you don't want to screw it down to the floor the norm because you don't want to rack the cabinet, or pull the joints free, some put down a 2 x 4 and glue/screw it down to the concrete floor inside of the case walls and then finish nail the case to it, when you don't have a wall to anchor it in place.
Concrete Floor Question Bob N DIY and Renovation 37 11-10-2009 05:02 AM
New Bathroom Renovation TRN_Diesel Show N' Tell 4 03-10-2009 11:41 PM
Fastening Router Table To Cabinet DONALD Table-mounted Routing 7 04-03-2005 11:04 AM
