solid surface sink removal - Router Forums
post #1 of 3 (permalink) Old 06-14-2011, 08:15 AM Thread Starter
First Name: Daniel
Default solid surface sink removal
I need to remove a solid surface sink from a counter top that is close to the back splash.
I have designed a way to do this, but need a large diameter cutting bit.
I have not been able to find one. probably because such a tool could be quite dangerous if ran over speed.
the bit would resemble a 6" dia saw blade with a 3" bearing above the blade on a 1/2 inch shaft.
would resemble velapec's 4 wing cutter but w/ larger dia. cutter.
Dan Ellard is offline
post #2 of 3 (permalink) Old 06-14-2011, 09:38 PM
Welcome to the router forum, Daniel
Such a large bit would seem to require a shaper table?
Not hand held, I trust.
Sydney, Australia
jw2170 is offline
post #3 of 3 (permalink) Old 06-15-2011, 03:27 AM
Phil P's Avatar
First Name: Phil
Take a look at Pinske Edge. They also rent sink bowl removal tools made specifically for the purpose at $250/week. I believe that Art Betterley may make something similar. Several companies make the rigid slotting cutters used in this process (saws wow and flutter too much). One I know is Velepec in NY who sell through a few specialist suppliers like Speciality Tools, in the UK the obvious candidate is Titman who sell a 4-flute Corian sink repair groover which is made for the purpose
Regards
Phil
Phil P is offline
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
Laundry Sink Project TRN_Diesel Show N' Tell 15 03-22-2009 12:01 PM
Laundry Sink Project TRN_Diesel Show N' Tell 2 03-09-2009 12:28 PM
Sink trays rh111 Starting Off 3 02-06-2007 11:42 PM
