Leveling a concrete floor - Router Forums
post #1 of 5 (permalink) Old 07-22-2011, 12:19 PM Thread Starter
First Name: David
Default Leveling a concrete floor
Hello, I just had a 16 x 24 wood shop built and the concrete is not level (I am not to happy with the quality of the work) any ways, what is the best way to level my floor?
The Mill Doctor
The Mill Doctor is offline
post #2 of 5 (permalink) Old 07-22-2011, 12:38 PM
Hi David
I would suggest and new floor over the one you have now, 2" thick should do the trick without adding to much mass..
The Mill Doctor
post #3 of 5 (permalink) Old 07-22-2011, 07:03 PM
paduke's Avatar
How far out of level? 1/4 plus minus is typical in concrete leaving 1/2" accumalative variation across floor. If your looking for a flat level floor you wil need to put down sleepers on concrete and shim all to level then sheath it with plywood.
But not sure how level your level is
paduke is offline
post #4 of 5 (permalink) Old 07-22-2011, 08:35 PM
First Name: Charlie
It's cheaper to put levelers on your equipment than it is to level that floor. Is it not level or is it bumpy? I have a 16x24 shop as well. My floor has a steel trowel finish and the control joints were saw cut (instead of tooling those wide control joints into it). It's VERY flat, level, and has a satin sheen from the troweling.
Almost makes me want to wax it
reikimaster is offline
post #5 of 5 (permalink) Old 07-22-2011, 11:42 PM
G'day David
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
Joke a Day bobj3 Lobby 3949 Today 02:18 AM
Floor board repair : female recess/male plug matt1710 Portable Routing 27 06-30-2011 06:30 PM
What's the easiest way of fastening the base of a storage cabinet to concrete floor? dbrode1 DIY and Renovation 4 04-26-2011 03:09 PM
Concrete Floor Question Bob N DIY and Renovation 37 11-10-2009 05:02 AM
