Mdf raised panel help - Router Forums
post #1 of 6 (permalink) Old 08-20-2011, 08:12 AM Thread Starter
First Name: Brad.
Cool Mdf raised panel help
hello everyone ! I am new to this forum and I am excited to have someplace to turn to for help while in a bind ! I am getting ready to build new cabinet doors for my kitchen that are white ! the edges are peeling after 15 years of use ! Will mdf be the best way to go and what is the best way to build these ?
Lights on is offline
post #2 of 6 (permalink) Old 08-20-2011, 08:46 AM
Woodhaven - Woodworking Tools, Supply & Equipment
Video | Woodhaven
post #3 of 6 (permalink) Old 08-20-2011, 09:55 AM
tdublyou's Avatar
First Name: Tim
Brad,
You can make a jig from a piece of plywood or MDF, and some hardwood strips that will do the same thing for a fraction of the cost.
Tim
"The difficult we do immediately... The impossible takes a little longer" - Grandpa
Don't worry about nothin', aint nothin' gonna turn out right anyway" - Dad
tdublyou is offline
post #4 of 6 (permalink) Old 08-20-2011, 11:44 AM
Hi Brad, MDF does not hold screws that well for cabinet doors that receive much use over time. A better combo for paint grade in the kitchen that is still inexpensive would be to make the frame (rails & stiles) out of Poplar & make the center panel out of MDF. A raised or flat panel can be made. Using the poplar for your frame pieces would not be expensive & the wood would hold your screws much better over time.
Here is a picture of some hall cabinet doors I made using Poplar for the frame & MDF for the raised panels in the center. Build them the same as you would any 5 piece cabinet door. For flat panel doors you will need a set of rail & stile bits. If you want raised panels you will also need a panel cutter. I prefer to use panel bits that have a back cutter so it will machine both sides of the center panel at the same time. Primer good before paint & they will give you many years of trouble free service.
Name:	Hallway 001 Large Web view.jpg
Name:	Hallway 007 Large Web view.jpg
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 6 (permalink) Old 08-20-2011, 06:59 PM
Nice job James. I always thought that wood and mdf wouldn't finish the same, but then I never thought of using poplar. Just out of curiosity, where did you get the poplar from. Alberta is 2/3 poplar and yet it is very hard to find poplar lumber here.
post #6 of 6 (permalink) Old 08-20-2011, 07:21 PM
Thanks Charles.
Around here in So Cal you can find it at Home Depot or Lowe's in 3/4" but I prefer to buy my material in 4/4 (actually measures 13/16") from Austin Hardwoods. The center panels were made from 3/4" MDF. You can use anything silmular in your area. As far as finishing the same in paint grade it just needs a good prime coat before paint coat is applied. The doors in the picture you cannot tell there is different material used in person.
Whittier, CA.
jlord is offline
1/2" Stock for Raised Panel rdlorenzo Router Bits - Types and Usage 5 11-19-2010 09:00 AM
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 09:11 PM
3 pass mdf raised panel doors (bits?) cabinetal Router Bits - Types and Usage 7 06-28-2010 09:50 AM
Adjustable Frame for Mdf Raised Panel Doors jerry433 Jigs and Fixtures 6 10-08-2009 02:22 PM
raised panel look mdf doors budman000 Jigs and Fixtures 1 04-27-2009 09:30 PM
