router repair? - Router Forums
post #1 of 6 (permalink) Old 10-14-2011, 04:13 PM Thread Starter
Default router repair?
B&D 7614-04 type 1 problem
i have never used this router before.
when i go to put in a router bit in and so tighten the top nut down ( missing from picture) ... well the whole shaft revolves!
the castle nut has no thread - it seems to be kept in place by the thin nut in the picture (no, not the photographer!).
how do i tighten that one?
there seems no way to hold the shaft still while i tighten it.
do i just go and get another wrench and then tighten the thin nut with the one the otherside of the collet?
but then what is the castle nut and lever for!
UPDATE: problem solved. there was a little halfmoon wedge that ties the castle nut to the shaft - by a miracle we found the wedge!
thanks all
anon125 is offline
post #2 of 6 (permalink) Old 10-14-2011, 04:36 PM
Hi
The lever is the lock, it looks like it has a place for your finger, push or pull it in to one of the slots..should lock the motor in place then use the wrench on the collet nut.
thanks all
post #3 of 6 (permalink) Old 10-14-2011, 06:18 PM
That is a bit of an odd design. There is a spring on the lever to push the tang away from the castle nut but it appears the factory didn't even trust it to work as they put a locking screw on the end of the lever just to make sure. I would be tempted to take it off and just use two wrenches instead. That would probably be faster as well.
post #4 of 6 (permalink) Old 10-14-2011, 07:31 PM Thread Starter
thanks
anon125 is offline
post #5 of 6 (permalink) Old 10-14-2011, 08:09 PM
Hi
Looks OK to me I don't think it's castle nut looks like it's part of the shaft to me and a great design,the spring it set to hold it out and not let it drop in the slot by error, the screw is just a way for the metal part to slide true and not a locking device..
post #6 of 6 (permalink) Old 10-14-2011, 09:17 PM Thread Starter
please see my UPDATE above.
thanks
anon125 is offline
Craftsman Router Repair Woodmills_74 DIY and Renovation 4 06-08-2010 01:37 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
Bosch 1617EVS router repair chiswoo Starting Off 6 07-02-2007 05:30 PM
