Perfect holes w/o drill press - Router Forums
post #1 of 4 (permalink) Old 01-11-2012, 05:08 PM Thread Starter
First Name: Shan
Question Perfect holes w/o drill press
The one tool I need to splurge on to complete my shop is a drill press. In the meantime, I need to drill a 3/8" wide bit through an 11/16 thick stock that is 5/4 wide. It has to be straight and true. Anybody know of any tricks or jigs to accomplish this with a hand drill?
lanemier is offline
post #2 of 4 (permalink) Old 01-11-2012, 06:11 PM
I would go with a plunge router. Add blocks or something to either side of the workpiece to give enough router support and an extra block or two to register the router against. Even if the router won't plunge all the way through, you should get a deep enough hole to be able to finish with a hand drill.
John Schaben
jschaben is offline
post #3 of 4 (permalink) Old 01-11-2012, 06:14 PM
You can make a corner block (like a piece of angle) to plumb the drill bit while drilling.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 4 (permalink) Old 01-11-2012, 08:14 PM
kp91's Avatar
First Name: Doug
kp91 is online now
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
Drill Press table (need input) jd99 Tools and Woodworking 8 08-04-2009 10:05 AM
Guide Bushing Holes and Drill Press cbsjoez1935 Jigs and Fixtures 2 10-08-2007 03:37 PM
