triming laminate with router ??? - Router Forums
post #1 of 4 (permalink) Old 04-23-2012, 06:41 AM Thread Starter
First Name: Joe
Default triming laminate with router ???
Hi I am building a frame and deck for a drop in bathtub I will be puting a laminate on it I have a regular router and a flush routing bit. With the regular router if I build the top frame and deck in place I can't trim all the way to the wall is there something I can do to finish the trim inplace or am I going to have the build the top of the deck first and then put it in place.
thanks for any info
Joe>G is offline
post #2 of 4 (permalink) Old 04-23-2012, 10:49 AM
argoknot's Avatar
First Name: john
I would build the top deck first. As for trimoni you should get a flush trim bit with bearing. It does a neat job.
Today is the first day of the rest of your life. Live it to it's fullest.
Making sawdust by the sea in Massachusetts
argoknot is offline
post #3 of 4 (permalink) Old 04-23-2012, 09:06 PM Thread Starter
First Name: Joe
Thought that is what I would have to do with the router I have to reach all the way to the end. The deck is going to be a foot or so wider for a sitting area so my wife can sit on the edge then get in. Thats the bit I have argoknot thanks
Joe>G is offline
post #4 of 4 (permalink) Old 04-23-2012, 09:08 PM
thanks for any info
Hi Joe - Not sure just what your situation is, I assume the router base is going to stop you 3" or so from the end of your cut. This is kind of a spendy option but the offset base for the bosch colt puts the bit on the offset part, not under the router.
Amazon.com: Bosch PR004 Offset Base With Roller Guide for the Bosch Colt PR20EVSK & PR20EVSNK Palm Routers: Power & Hand Tools
(The bit is directly below the red cap and is belt driven from the motor)
John Schaben
jschaben is offline
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
