hardwood flooring Houston - Router Forums
post #1 of 7 (permalink) Old 04-26-2012, 04:50 AM Thread Starter
Smile hardwood flooring Houston
hi,
My hardwood floors have lost their shine. How do I get them to look like they did when they were new? hardwood flooring Houston
loreanice is offline
post #2 of 7 (permalink) Old 04-26-2012, 06:46 AM
First Name: Art
Use a product called "Rejuvenate" you can find it on the web or at Home Depot, Lowes etc
mgmine is online now
post #3 of 7 (permalink) Old 02-19-2013, 12:31 AM
jeffjacob's Avatar
First Name: Jeff
Use Murphy's Soap to wash the floors. You can also use Oxy- Clean it also works great.
jeffjacob is offline
post #4 of 7 (permalink) Old 04-15-2013, 06:34 AM
PaulsonJacob's Avatar
First Name: Paulson
Would suggest you to go for polishing the floors, so that it becomes brand new
sisal area rugs
PaulsonJacob is offline
post #5 of 7 (permalink) Old 04-15-2013, 07:26 AM
IC31's Avatar
First Name: Dave W
While the previous responses may work just fine in your case, sometimes you just have to bite the bullet ($$$), call in the pros, have the old finish power sanded off, then refinished.
Dave W
Quando omni flunkus, moritati (When all else fails, play dead - R Green)
IC31 is online now
post #6 of 7 (permalink) Old 04-15-2013, 07:30 AM
Hi, 'Loreanice'; welcome.
You didn't say whether or not you've been waxing and polishing them, or rather it's the finish itself that's worn(?)...
If you've never waxed them, don't start now! If the finish needs redoing, the wax would mean floor-sanding it down to bare wood (in order to recoat).
If, on the other hand, it'd never been waxed, there's an excellent chance that it could be cleaned with a commercial floor machine, and recoated, assuming you know what kind of finish was previously on there. Seriously, you need to talk to a hardwood floor finishing contractor.
My fear would be that it was one of those laminate hardwoods and can't be refinished, if it needs to be floor sanded...
DaninVan is online now
post #7 of 7 (permalink) Old 04-24-2013, 02:39 PM
First Name: Jack
However, this post is already one year old. She probably had polished her problem.
bosox is offline
Hardwood flooring for router table top sofasurfer Table-mounted Routing 5 01-13-2010 01:51 PM
salvage hardwood flooring MOOSEYCAT13 New Member Introductions 5 07-27-2009 02:14 PM
5 Tips When Choosing Hardwood Flooring John_smith Project Plans and How To 0 10-17-2008 06:19 AM
Gathering hardwood to work with... popeyebedford Lobby 1 07-16-2007 09:19 AM
Hardwood flooring Rosco4 General Routing 9 04-28-2006 08:58 AM
