House Staircase Construction - Router Forums
post #1 of 13 (permalink) Old 04-30-2012, 11:42 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default House Staircase Construction
Hi,
I own a 1930s semi detached house, I'm looking into replacing the staircase. I don't want to restore the staircase, I want to build a contemporary style design.
I've found a few books on staircase construction and I've looked at the reviews on Amazon. I'm thinking I might have missed some titles worth reading. In case I have, can anyone suggest any books worth having a look at. I've had a quick look on the net, couldn't find much on the subject. Are there any resources on the net I might find helpful.
Gaia is offline
post #2 of 13 (permalink) Old 04-30-2012, 12:37 PM
Phil P's Avatar
First Name: Phil
Hi Peter
Straight run or with kite winders?
Regards
Phil
Phil P is offline
post #3 of 13 (permalink) Old 04-30-2012, 12:50 PM
" kite winders ' = ?????
fOUND IT
http://www.google.com/search?q=kite+...w=1037&bih=576
post #4 of 13 (permalink) Old 04-30-2012, 01:24 PM Thread Starter
Gaia's Avatar
First Name: Peter
From what little I know, so far, the staircase type I have is a 1/4 turn winder. Been looking at staircase maker sites, quite informative. Then again....... a little knowledge can be a dangerous thing
Gaia is offline
post #5 of 13 (permalink) Old 04-30-2012, 01:32 PM Thread Starter
Gaia's Avatar
First Name: Peter
I'm buying a Dewalt 733 thicknesser/ planer, also a planer knife sharpening jig to go on my Scheppach wetstone grinder. Looking at the actual winder treads themselves, can't put them through the Dewalt. How do I go about getting them done?
Cheers.
Gaia is offline
post #6 of 13 (permalink) Old 07-30-2012, 04:56 PM
monty.smith's Avatar
First Name: Monty
Peter,
Ok so If I have a project that requires larger tools or machinery, I will go to the craft store and they will recommend a cabinet shop that will assist the hobby worker, I have built a cabinet makers bench, I picked up two flat railroad care decking, Laminated Oak 24"w 4"d 8'L, The local shop recommended a cabinet worker who had a large belt sander. It turned out flat and square for $20.00USD, Couldn’t ask for anything better.
I know this is a few months later than your last post maybe it will help?
Monty
monty.smith is offline
post #7 of 13 (permalink) Old 07-31-2012, 06:18 AM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by monty.smith View Post
Peter,
Monty
OK thanks Monty,
Had sort of though of that, though more along the lines of another hobby woodworkers shop, asking for a favour, if they had suitable equipment. By what you advised, now thinking if need anything bigger done, will search out a smaller woodworking industrial type unit. Yeah good price you got, I'm always shopping around for the best deal, not because I have to, just enjoy getting a good deal
Peter.
Gaia is offline
post #8 of 13 (permalink) Old 07-31-2012, 12:16 PM
Phil P's Avatar
First Name: Phil
Hi Peter
Two ways - sub out planing/thicknessing all the treads to a joiners shop where they have a 24in thicknesser or (better) a wide belt sander or machine up the stock yourself and then glue-up the stock (using loose tongues). The latter might require a small amount of attention with a sharp plane and scraper afterwards.
A further thought is how are you ever going to handle machining the stringers? These are in the order of 14 or so feet long x 10 to 12in wide x 1-1/2 to 2in thick and are just far too large to machine in a small workshop (in fact they're hard enouigh to do on a 2.5 metre long overhand planer and a 24in thicknesser - a 2 man job at least). On softwood stairs it is easy enough to just buy dry graded stringers to the approximate correct dimensions from a timber merchant - hardwoods would need to be bought rough sawn and then machined to order. In either case you'd still need to glue on your own fillets (called "easings") to handle the winder ends
One point I would caution you on is the use of American textbooks on a stairway in the UK because the USA has different requirements to here (vice versa is also true). Stair installation/replacement is classed as notifiable work (i.e the Building Inspector should be informed but won't necessarily come to inspect) and all flights of stairs must conform to UK Building Regs to avoid either a fine, problems when you come to sell your house or problems with your mortgage provider/house insurers (fall down a non-legal flight of stairs you made and installed yourself and you'll find out what I mean). Fortunately the calculations aren't difficult and were I you I'd be looking at something like books by Porter & Rose, Goring or Brett (all City & Guiild textbooks) . After supper I'll look through my small library and try to find you the best book for you to get hold of
Regards
Phil
Phil P is offline
post #9 of 13 (permalink) Old 07-31-2012, 03:46 PM Thread Starter
Gaia's Avatar
First Name: Peter
Phil[/QUOTE]
" Two ways - sub out planing/thicknessing all the treads to a joiners shop where they have a 24in thicknesser or (better) a wide belt sander or...... machine up the stock yourself???
The treads forming the 1/4 turn winder are to large to go through the Dewalt. When you say machine them myself, do you mean these treads? All the other treads can be handled by the Dewalt. What would be the other method of thicknessing the 1/4 turn treads?
" A further thought is how are you ever going to handle machining the stringers? "
The top of the wall mounted stringer is curved going toward the 1/4 winder, before I abandoned the idea of getting a 14 inch bandsaw, I thought could use the bandsaw to cut the curve. With the bandsaw I could have started with an oblong block, cut on the bandsaw to required thickness, then cut the curve. Think that might have been quite a waste of wood, the scrap.
" (fall down a non-legal flight of stairs you made and installed yourself and you'll find out what I mean). " Exactly
" Fortunately the calculations aren't difficult and were I you I'd be looking at something like books by Porter & Rose, Goring or Brett (all City & Guiild textbooks) . "
OK will check them out.
" After supper I'll look through my small library and try to find you the best book for you to get hold of. "
Brill much appreciated.
I think I got a really good price on the Dewalt 733, £399 inc vat inc delivery, also got the Schappach thicknesser knife sharpening jig to fit the wetstone grinder.
Gaia is offline
post #10 of 13 (permalink) Old 07-31-2012, 03:49 PM
Phil P's Avatar
First Name: Phil
Hi again Peter
As to books the one which would probably serve you best would be Peter Brett's "Carpentry & Joinery: Book 2 - Practical Activities", ISBN978-0-7487-8502-5 publ. Nelson Thornes, circa £19. This book is written as part of the City & Guilds/NVQ training curriculum and contains information about flat and pitched roof construction, partition (stud) walls, timber frame construction, stairs, doors, frames and linings, windows (casement, bay, swivel, vertical sliding sash, etc), etc It is emphatically NOT a DIY guide and it assumes a basic knowledge of joinery woodworking, e.g. tools, materials, joints, setting out, applied geometry and applied calculations (which if you want to learn more are in Vol. 1 of Mr Brett's books), but it contains the kernal of knowledge for many of the projects you seem interested in.
One other point about stair building which you might consider - assembling a flight of stairs isn't really a one-man job; installing them, especially those with a winder (which requires some on-site assembly) absolutely isn't
Regards
Phil
Phil P is offline
House blew up! jd99 Lobby 4 10-02-2009 07:14 PM
Construction Tricks of the Trade bobj3 General Routing 2 07-18-2006 05:27 PM
