countertop laminate contact cement ??? - Router Forums
post #1 of 4 (permalink) Old 06-11-2012, 07:54 AM Thread Starter
First Name: Joe
Default countertop laminate contact cement ???
Hi all I am putting in a drop in tub and I am doing the frame and deck for it right know.
I am going to put a laminate down on 3/4 plywood I am nailing the plywood to the frame will the contact cement stick to the nails or will I have little bubbles were the nails are. Or am I going to have to counter sink the nails and puddy over them.
Thanks for any info you can give.
Joe>G is offline
post #2 of 4 (permalink) Old 06-11-2012, 10:07 AM
'Morning, Joe; Welcome, by the way!
Joe, are you talking about plastic laminate (Arborite), or wood?
If you mean plastic, then you should probably screw down the plywood, and make sure the heads are slightly countersunk, whichever you use...with nails there's always the risk of them working their way back up slightly, and with the weight of someone walking on the deck, breaking through the laminate.
If you were thinking of wood laminate, don't. There's no place for wood laminate where there's water. Baaaad combination!
If you want to level off the countersunk fastener holes, just use autobody filler, and sand flat after it cures. The stuff comes in small cans and is pretty cheap...and waterproof. Contact cement doesn't really need to penetrate the substrate if the surface is impervious, so sealing the plywood is probably good insurance considering the water issue.
(35 years of dealing with water damage in peoples bathrooms has made me paranoid about water. )
Cheers,
-Dan
DaninVan is online now
post #3 of 4 (permalink) Old 07-05-2012, 07:03 PM
TRBaker's Avatar
First Name: Troy
I totally agree with what Dan said. I've done a bunch of them but I don't recess my screws. I flush them up and sand the tops flush with a belt sander. I've never had any problems with the glue releasing, but if you feel more comfortable filling them, then by all means, use bondo.
TRBaker is offline
post #4 of 4 (permalink) Old 07-06-2012, 06:06 AM
Phil P's Avatar
First Name: Phil
Hi Joe
I'm also with Dan - nails are a bad idea because they will work loose and eventually telegraph through the laminate. Like him I sink and fill the heads - I don't like contaminating my sanding belt with steel filings which are a sure fire problem creator if your next sanding task happens to be oak, walnut or mahogany
Regards
Phil
Phil P is offline
spraying contact cement, lets talk! Jack Wilson Lobby 7 02-26-2012 01:32 AM
Bearing bit and contact cement papasombre Router Bits - Types and Usage 11 01-30-2012 08:44 PM
Laminate countertop and stove headlessblade DIY and Renovation 1 04-13-2011 10:03 PM
Laminate Countertop help brenna7777 DIY and Renovation 5 11-20-2010 12:50 PM
Contact Cement for MDF Cassandra Table-mounted Routing 28 04-30-2010 10:39 PM
