Redwood Expansion Joint Replacement - Router Forums
post #1 of 3 (permalink) Old 06-16-2012, 01:42 PM Thread Starter
neiltsubota's Avatar
First Name: Neil
Default Redwood Expansion Joint Replacement
Hello Everyone.
I have a "honey do list" that involves replacing all of the Redwood Expansion joints in my driveway and Patio. I live in the People's Republic of California. (Uhg....) It is planned to get over 100 today on this driveway.
My plan are to drill 2" into the 'floated' driveway and 1" into the Redwood, place a plug and screw a #8 screw into the plug.
Here are some pictures.
Any opinions welcome ( if not encouraged )
I can't get the Manage Attachment to work....So try this to the photos:
Flickr: Old Nikon Rangefinder shooter's Photostream
neiltsubota is offline
post #2 of 3 (permalink) Old 06-16-2012, 02:33 PM
Default Groovy!
Hi, Neil; I'm not sure what the question is(?)...
Are you looking for a way to remove the old wood? Or anchor the new wood?
If the new wood is bone dry when you install it, a simple light pressure should be all that's required to seat it. If it's wet, don't. It'll shrink, and that's where the weeds will set up shop.
If the question was how to remove it, I'd set my saw blade a 1/4" less than the original depth and run a kerf right down the middle...then split either side off in towards the kerf.
I can't see any reason for there to be any nails in it except for the junctions. Use a demo blade (just in case) and you're good!
The old stuff didn't look that bad in the pictures; is it worse than it appears?
Neil, you might also consider giving the new wood an allover coat of a preservative stain before installing it. Concrete is really hard on wood; I think it's likely the high pH, and it reacts for a very long time, hence the protective treatment.
Cheers,
-Dan
DaninVan is offline
post #3 of 3 (permalink) Old 06-17-2012, 06:46 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Neil, if you want that to function as a true expansion joint; redwood is not the answer. Coming from a background including structural engineering and concrete formwork, you need to clean-out the joints, mask-off the joints and use some form of caulking that will include a liquid primer - applied to clean, dry concrete. Thiokol is the best of the caulkings that I am familiar with. Also important is the placement needs to take place at a mean (average) temperature - rather than the 100 you referred to (extreme). Follow all of the manufacturer's printed instructions. Some caulkings are available in colors, also.
OPG3
Tweak everything!
OPG3 is offline
Sash Corner Bridle Joint & T Bridle Joint Gaia DIY and Renovation 19 01-27-2012 03:29 PM
Choice-Best joint gemnw Tools and Woodworking 0 08-30-2010 12:16 PM
The first through dovetail joint by AKEDA Benny LaBaw Jigs and Fixtures 9 12-14-2009 08:01 AM
Incra half blind joint S Bolton Jigs and Fixtures 7 10-23-2007 01:38 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
