Aspen wood fading - Router Forums
post #1 of 16 (permalink) Old 07-16-2012, 09:09 AM Thread Starter
First Name: Ray
Default Aspen wood fading
This may not be the place to post this but I need some help.
The Aspen wood paneling or maybe the clear coat has faded and I can't find a way to get rid of it. Tried cleaning, scrubbing it, but that didn't change anything. See attached picture.
Any idea on what I can do about it?
ChevyNomad is offline
post #2 of 16 (permalink) Old 07-16-2012, 02:47 PM Thread Starter
First Name: Ray
Several lookers but NO ideas ? ? ?
Should test to see if the clear coat is lacquer?, and if it is would rubbing the area down wth lacquer thinner work?
HELP ! Need ideas
post #3 of 16 (permalink) Old 07-16-2012, 04:22 PM
Ray; It's highly unlikely that it's a lacquer, far more likely to be some kind of varnish, but I think Mohawk Finishes has some kind of quick test...(or maybe you have to take a sample in to them(?).
Wood & Leather Touch Up & Repair Products by Mohawk Finishing
In any case, they're great folks to talk to about this kind of issue.
If it were my situation, I'd be looking for some type of tinted clearcoat, with UV protection if possible...maybe an exterior product (for the UV factor) ok for interior use?
Please let us know the outcome!
DaninVan is online now
post #4 of 16 (permalink) Old 07-16-2012, 05:13 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Ray, are you certain of it to be Aspen? It looks to me like Southern Yellow Pine - which is notorious for having light spots. If it is, in fact; SYP - you may just need to clean it with mineral spirits and refinish to your satisfaction. Good luck!
OPG3
Tweak everything!
OPG3 is offline
post #5 of 16 (permalink) Old 07-16-2012, 05:36 PM Thread Starter
First Name: Ray
No, I'm not positive that it's Aspen. That's what the builder said. I agree it looks like Southern yellow pine.
I'll try some mineral spirits.
post #6 of 16 (permalink) Old 07-16-2012, 08:44 PM
Marco's Avatar
The Light areas shapes are all similar, are they being faded by a light source? Not sure of the wood species but it looks great! And hope you find a solution to the problem areas.
Galatians 5:13
Marco is offline
post #7 of 16 (permalink) Old 07-17-2012, 06:55 AM
First Name: Fred
It sure looks like a picture was hanging in these spots which prevented the wood from getting its natural patina like the rest of the wall. I had this same problem at my cottage which forced me to continue to move the pictures around over the years.
routerworks is offline
post #8 of 16 (permalink) Old 07-17-2012, 07:15 AM
OPG3's Avatar
First Name: Otis
Ray, I've reviewed this a second time - which included a study of what has been sent by other members.
1. You do not need UV protection indoors unless someone will be using UV bulbs (which is highly unlikely). I am certain Dan already knows this.
2. Thinking about what Jim (Marco is his dog's name) said, I now agree that the fading is a result of uplighting - review the photo and note how the partial ellipses are aligned with the coursing of the wood planking - that IS EXACTLY how the wood would fade in that scenario.
3. One might assume that uplighting (from a previous owner) would have left screw hole "scarring" on the walls, but this could be avoided with an adhesive mount.
4. My wife and I have been told "Aspen Siding" on numerous occasions when looking at mountain properties (such as chalets, cabins, etc.). It refers to something one might see commonly used in Aspen, Colorado.
5. I would bet that wood is Southern Yellow Pine, but my earlier recommendation of mineral spirits is NOT GOING TO HELP.
6. Unless you wish to refinish the entire wall, you will probably do best to hide those spots with some framed art. Good luck!
OPG3
Tweak everything!
OPG3 is offline
post #9 of 16 (permalink) Old 07-17-2012, 09:36 AM
Otis; pf course, but I was referring to sunlight from South facing windows...can't tell from the pic if that applies in this case. With modern Low-E glass it's not such a problem anymore, but it certainly used to be an issue with the furniture and fabrics.
We just got our family rm. drapes back from the dry-cleaners and in the process of rehanging them I noticed how much the fabric had faded where the sun hits them.
post #10 of 16 (permalink) Old 07-17-2012, 09:40 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
As I look at those lighter patches they look remarkably like the back plate on the set of bull horns, did anyone ever have some more of those things hanging on that wall? The lighter areas are so uniform in size and the border lines between the lighter and darker areas is so well defined that they look like something was very close for a few years, no light or UV light shining from a distance would do that as no light source could focus it beam so exactly as to leave those well defined borders, as it looks like something was very close for some time then I would just leave it alone, as with all things, time passing would help, if you do hang up something else and leave it there for a few years then that new item will leave it's own shaded area when you take it down, I love wood even when it hurts. NGM
neville9999 is offline
Wood Species dattashri Wood Species 7 07-26-2012 10:23 AM
Exterior wood Treatment dattashri The Finishing Touch 3 05-14-2012 11:37 AM
Attaching Patterns To Wood Vector01 Wood Scrolling 4 10-18-2011 01:50 AM
Best Places to buy wood? big wes New Member Introductions 12 01-26-2010 04:34 PM
