Door skin? - Router Forums
post #1 of 19 (permalink) Old 09-13-2012, 08:14 AM Thread Starter
L Town Graphics's Avatar
Default Door skin?
Hey guys, I am looking for some suggestions. I have an old stone house, built in 1932. My outside door is in need of some help. The bottom is rotted pretty good. I know most of you would say just buy a new one.... Here's the problem, to replace it will cost about $2500. Reason being it is round at the top and tapered on the sides. We had a family friend who is a contractor take a look at it. What he suggested is to have the door reskinned. In terms of cost efficiency it makes sense. With all of that being said I'm looking for suggestions on what type of wood to do the skins. Something that looks nice finished and durable. The door faces the south east and is in direct sunlight atleast half of the day as well as the natural elements of rain and snow. Thanks in advance for any input.
"the last person that was perfect was crucified"
Find all of my work both wood and vinyl on Facebook
-coming soon- www.ltowngraphics.com
L Town Graphics is offline
post #2 of 19 (permalink) Old 09-13-2012, 10:11 AM
Gene Howe's Avatar
First Name: Gene
The skin material is probably less important than the glue used and the finish you apply.
Use a water proof glue such as Titebond III.
I would apply a skim coat of glue to the very bottom of the door, also.
For a final finish to the door skin, I've had great luck with McClosky's Man-O-War varnish. I'm sure there are others just as good, though.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 19 (permalink) Old 09-13-2012, 06:50 PM Thread Starter
Gene, I will be sure to let the contractor know to do those things.
Does anyone have have a recommendation on what type of wood?
post #4 of 19 (permalink) Old 09-13-2012, 08:04 PM
Dan; you maybe limited in what's available with an exterior rating (the laminating glue).
DaninVan is offline
post #5 of 19 (permalink) Old 09-14-2012, 01:03 AM
MAFoElffen's Avatar
Dan-
(Restoration Carpentry) Most exterior doors from that era are oak or mahogany.
You described the shape of the door, but... No-one asked this. What is the construction of this door? Solid? Panel? Ledge and Brace? Etc.
The cheapest repair if it is a paint out is also the best weather resistance wise. Treat the rot, fill the voids, skin it with fiberglass and paint it.
If a stain and finish, the repair all depends on the construction.
Even if a solid door, the bottom could be trimmed, routed or shaped with a spline joint and a bottom piece attached. Make the spline joint so joint sheds down and there you go. Add a few dowels and bolts to add some strength. Just like a glueup- you can make it look like the joints are seamless.
If a panel door or ledge and brace, remove the bottom panel (cut and chisel) Replace the panel... If the stiles are rotten then make the joints at different places than the panel joints, to give it strength. Ledge and Brace is the same repair. Ledge and Brace construction is braces jointed vertically supported between 2 Braces.
Etc.
Have a photo handy of that door?
MAFoElffen is offline
post #6 of 19 (permalink) Old 09-14-2012, 02:03 AM
Dan; did you check out the 'used building material' outlets? They usually have hundreds of old doors in stock.
DaninVan is offline
post #7 of 19 (permalink) Old 09-14-2012, 02:15 AM
Why a door skin they are easy to make with the right bit set.
Short cuts just don't worked out well the norm,the hardware you now have on the door may not fit with a door skin.. ;(
2 pc 1/2" SH Entry Door Matched R&S Router Bit Set | eBay
post #8 of 19 (permalink) Old 09-14-2012, 07:13 AM
First Name: Browne
Birchwood Best,http://www.birchwoodbest.com/doorskins.php, should be able to answer all of your questions. They manufacture doorskins.
elrodqfudp is offline
post #9 of 19 (permalink) Old 09-14-2012, 07:22 AM
First Name: Art
Around my area there is only one place that sells door skins and they are made of luan. I'm guessing that you won't have much better luck finding a skin. I think the best you could hope for would be 1/4" marine grade plywood. Once yo put that on you will have to rest your hinges and lock as was Bob eluded to. I would try what Mike suggested and fix the rot, Minwax sells a product that will do that. If the bottom is somewhat solid instead of cutting it completely off you could route out the bad part and insert a new thin section. Even if you had to take it down an inch you would still have enough left to hold things together. Since you would most likely be routing the tenon away you would have to route the complete width including the stiles. To cover things you could then attach a brass door bottom panel.
mgmine is offline
post #10 of 19 (permalink) Old 09-14-2012, 10:10 AM
JOAT's Avatar
First Name: Theo
No, I wouldn't say buy a new one. Unless you wanted to repair the old one, I'd say make a new one. It's not rocket science, and there are instructions on door making on-line if you're not sure about how to do it. Solid door for outside.
It would be a definite help if you had pictures, your description is lacking detail. The Devil is in the details.
JOAT is offline
