Barrel nuts - Router Forums
post #1 of 10 (permalink) Old 11-15-2012, 01:38 PM Thread Starter
Country: South Africa
First Name: moki
Smile Barrel nuts
Has anyone here used barrel nuts? I have never used these before and would like to know what distance from the edge of the wood are the holes for the barrel nuts drilled.
I have some 6mm nuts - thread size. The outer diameter is 10mm and depth is 13mm. I believe these form excellent joints.
I hope I am posting in the correct place!!
Thanks in advance.
moki is offline
post #2 of 10 (permalink) Old 11-15-2012, 01:49 PM
Hi
I use them all the time on softwoods like MDF /PB etc. 1/16" from the edge will hold them..
You can make your own easy with some brass rod to help with cost of them.
I have about 20ea. in my router table.
Thanks in advance.
post #3 of 10 (permalink) Old 11-15-2012, 02:35 PM
First Name: Chris
bob, what do you use the barrel nuts for in your router table?
i can see maybe tee-nuts, but barrel nuts?
Chris Curl is offline
post #4 of 10 (permalink) Old 11-15-2012, 02:55 PM
Hi
For the top and sides,a quick hole for the barrel nut and a quick hole for the screw.
A simple butt joint and it's done.. works great with the pocket hole jig for the top, and can be taking down easy if needed..
I got the tip from Sommerfeld router table..
http://www.routerforums.com/table-mo...e-cabinet.html
Name:	round nuts A.jpg
post #5 of 10 (permalink) Old 11-15-2012, 03:25 PM
First Name: Chris
oh, i see now, thanks.
i have some in my portable workbench as well, to hold the legs and sides together, but i only needed 8: 2 for each leg, near the top and bottom.
then again, if i were going to attach the top using them as well, that would put me up to 12, unless i did 2 on each edge, which would get me to 16.
post #6 of 10 (permalink) Old 11-15-2012, 04:13 PM
I used them to attach the stretchers on my workbench. I set them back about 2 to 2 1/2". But it depends on what you are using them for, size, and material I would think.
post #7 of 10 (permalink) Old 11-16-2012, 10:10 AM
First Name: Paul
Ditto to what Chuck said. It would depend on the material and the stress you anticipate.
PRDarnell is offline
post #8 of 10 (permalink) Old 11-16-2012, 11:57 AM
Wildwood's Avatar
First Name: Rob
Hi Moki - can you tell me where in SA I can buy these - I have been looking for them for a while now.
Wildwood is offline
post #9 of 10 (permalink) Old 11-19-2012, 03:30 PM Thread Starter
First Name: moki
I bought some from Gelmar. They are 95c each. They only had barrel nuts for a 6 mm screw. Gelmar seems to have branches throughout the country. I am sure you will find some in your area. Check out their website as well.
Regards
moki is offline
post #10 of 10 (permalink) Old 11-19-2012, 05:57 PM
Honored Member
First Name: pat
"Has anyone here used barrel nuts? "
******************************YES
(Soon to have a x-dowel locator/drill templet at the ready.)
Are you into edge or face grain?
In face grain there is not necessarily a target issue.
In the edge there is.
Depending on your source, the the major diameter of one of these pills (1/4-20) is .404-.406".
And an 1/8" (~3.2mm)/side, (a centered pill), would be acceptable.
Quillman is offline
Best Glue For T Nuts Into MDF Gaia Jigs and Fixtures 22 09-07-2012 08:48 PM
Using Barrel Nuts In MDF Jig Gaia Jigs and Fixtures 15 06-19-2012 04:17 PM
Where Can I get These Jig Wing Nuts? Gaia Jigs and Fixtures 22 05-18-2012 04:56 PM
5mm barrel hinges awoodnut General Routing 8 11-17-2009 05:28 PM
Hello to all wood nuts, like us.. twohawks686 New Member Introductions 5 05-25-2007 11:40 AM
