Kitchen Pullout Drawer Assembly - Router Forums
post #1 of 9 (permalink) Old 02-09-2013, 07:25 AM Thread Starter
First Name: Pete
Default Kitchen Pullout Drawer Assembly
Getting ready to cut some Baltic Birch plywood for pullout drawers, and I have 2 questions if I may;
1- when assembling using glue, butt joints and brad nailer, do the sides/front/back go on Top of the drawer Bottom, or on the sides?
2- using a 140 tooth plywood blade, how to limit splintering?
Thanks.
ptofimpact is offline
post #2 of 9 (permalink) Old 02-10-2013, 08:54 AM
Thanks.
1- I use a glued dado joint on the bottoms since, with plywood, you aren't particularly concerned with expansion. I like the dados over butt joints because with plywood the joints are all at least 50% end grain.
2 - I am assuming a table saw. Run the good side up. Blade set low, about 1 to 1-1/2 gullet showing above the stock. If still a problem, try taping and/or scoring the cut line, both sides.
John Schaben
jschaben is offline
post #3 of 9 (permalink) Old 02-11-2013, 07:33 AM Thread Starter
First Name: Pete
Default Thank you
John, thanks, I am cutting with an ods craftsman circular saw, 7 1/4 inch blade.
post #4 of 9 (permalink) Old 02-13-2013, 11:38 AM
MAFoElffen's Avatar
But for clarity- (traditonally)
- Sides dado'ed or joined for front and back. Force is pulled from front, transfered to sides and pulls back.
- Front and sides are dado'ed for bottom. Rear is flush with top of sides, but not as tall, as it is even with the top of the dado which holds the bottom.
So the bottom slides in sides, into the dado in the back of front, passes under, flush with the bottom of rear and ends at the back of rear. Usual attachment is staples through the bottom into the bottom of the rear.
For extra wide or heavy duty drawers, I cut the rear the same height as sides and front and dado the rear for the bottom, for a rear dado to add extra support.
7-1/4" saw? Ouch. Possible routered dado's?
MAFoElffen is offline
post #5 of 9 (permalink) Old 02-14-2013, 07:45 AM Thread Starter
First Name: Pete
John, again thanks for your help, will probably try the router dado route, and hope the ply does not explode on me. Yes an old 7 1/4 craftsman, dont see a table saw in my near future, but have a craftsman router table and router, use what we have.
post #6 of 9 (permalink) Old 07-02-2013, 06:50 AM
First Name: Aisha
Have you done it successfully without exploding on you????
AishaLawson is offline
post #7 of 9 (permalink) Old 01-02-2014, 12:49 AM
First Name: Rey
I would suggest you to hire any expert craftsman who can help you, as doing it yourself can be sometime a problematic as we are not expert in it and I have faced a problem when I tried my hands in it. So it will be good to take anyone's help rather then doing it yourself.
reyeliseo is offline
post #8 of 9 (permalink) Old 11-11-2014, 06:24 AM
First Name: Peter
Its better to hire professional expert contractor who has experience of this work,as to make pull out drawers one should have finishing in the work and their are lot many things into consideration.As my kitchen furniture was made by denver structural engineer.And they will make pull out drawers according to your ideas.
peterward is offline
post #9 of 9 (permalink) Old 04-07-2015, 12:05 AM
First Name: Alana
Thanks.
Brush the glue on the dove-tails and insert them carefully into the notches of the back component and after that repeat it for the front component and the other side to form a rectangular frame. Tap the joints gently into place with a mallet. Attach the drawer glides to the sides of the shelf.
But I must say you must go for professional work. We have such drawers in our new granny flats kitchen.
APridham is offline
How Does One Make Face Bevel Cut In Drawer Face For Standup Desk? tkleff General Routing 10 02-28-2013 01:15 AM
Kitchen Cabinets London atiyah New Member Introductions 0 06-18-2012 03:27 AM
Information about Basic Drawer Construction learnexperience General Routing 3 11-01-2011 09:23 PM
Information about Basic Drawer Construction learnexperience General Routing 0 11-01-2011 07:08 AM
Garage Overall for Shop TRN_Diesel Workshop Showroom 558 10-24-2010 02:44 PM
