coping oak baseboard. - Router Forums
post #1 of 15 (permalink) Old 04-03-2013, 07:26 PM Thread Starter
First Name: Billy Mike
Default coping oak baseboard.
I have found it next to impossible to use a regular coping saw for coping this oak.
Does anyone know of a better way?
mbokie5 is offline
post #2 of 15 (permalink) Old 04-03-2013, 07:33 PM
kp91's Avatar
First Name: Doug
Cut a 45 degree angle on the baseboard to give you the perfect outline for the cut. You can then cut with a coping saw or a jig saw.
If you have a lot to do, they sell a coping shoe for your jigsaw to make it easier.
http://www.collinstool.com/base.php?...oping_foot.htm
http://www.hartvilletool.com/product...aw-accessories
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 15 (permalink) Old 04-03-2013, 07:50 PM Thread Starter
I knew about the 45. I also knew there was a jig like the 2nd one, but did not have enough posts to link that.
Have you used either of those rigs?
Is there a best blade?
mbokie5 is offline
post #4 of 15 (permalink) Old 04-03-2013, 08:23 PM
Semipro's Avatar
First Name: John_*
N/a
Do not know if is kosher but could not find coping saw once used my dermal
a small sanding drum cut the 45 and ground it down, work great do not know if I would want do a whole house.
John
Semipro is offline
post #5 of 15 (permalink) Old 04-04-2013, 03:35 AM
Phil P's Avatar
First Name: Phil
I use a Collins Coping Foot for scribes (copes). It requires a T244D blade - no other will do (it has a fair amount of side set for cutting curves) - it also requires a simpler jigsaw so the Bosch and Festool models with extra blade guides won't accept it. For those who've never seen one, the "boat-shaped" silver foot on the jigsaw is the Collins Foot
For safest/fastest use you should make yourself a simple box jig to hold the moulding you are scribing.
Works well and is very fast. I have done some very big jobs with this tool. A good coping saw man is almost as fast for the first couple of cuts, but after 30 or so you do tend to slow down using a manual saw - the jigger never tires!
Above: Waste cuts to speed-up scribe (cope). On simpler skirting (baseboard) cuts this isn't necessary
Below: The scribe (cope) being made. This never fails to scare the bejesus out of quite a few of my colleagues but it's actually quite safe so long as you keep the "spare" hand behind the blade. The jigsaw is used inverted and from beneath to allow you to make a clean cut (the blade is cutting downwards into the finish side), add back clearance and to give visibility on the cut line
Below: A completed scribed (coped) joint. This is an extremely deep sprung architrave moulding (more like cornice/crown moulding) in solid oak which would have possibly pulled apart had the joint been mitred. The plasterwork was also a couple of degrees off square
That saw is a very beaten-up old Metabo D-handle jigsaw - nothing special - when it died it was replaced by another old jigsaw, this time a body grip model which is easier to manouver in sharp corners
Regards
Phil
Phil P is offline
post #6 of 15 (permalink) Old 04-04-2013, 05:51 AM Thread Starter
Awesome!
Thanks to all. I can pick up the blue jig for cheap and will order the foot just to see how it goes.
Thanks again, most kindly.
mbokie5 is offline
post #7 of 15 (permalink) Old 04-06-2013, 03:02 PM
Bradleytavares's Avatar
First Name: Bradley
You could do it on a table saw after you cut the 45 degree. Makes the long point real sharp.
Bradleytavares is offline
post #8 of 15 (permalink) Old 04-06-2013, 04:15 PM
Phil P's Avatar
First Name: Phil
Hi Bradley
Nice idea, and there is (was?) a machine out there which does (did?) something along those lines called a Copemaster but that's a whole different ball game, not to mention expensive (at circa $2300 - or rather it was, sadly the makers seem to have disappeared).
As for using a table saw I can see a few rather major problems with that - skirting board (baseboard) can often be really long pieces, even in oak it's not uncommon to have to scribe (cope) pieces 10 or 12ft long which would be simply unmanageable on a table saw IMHO, especially single handed (the Copemaster moved the blade relative to the material). Having tried this with smaller pieces I have to tell you it isn't easy to make a good cut without either over cutting or undercutting (both time wasters) and on some deeply shaped mouldings the saw blade can break through in the wrong place. Another issue will be the hassle of dragging both a table saw and a mitre saw around site with you (together with the box load of other tools like pinner, caulking gun, block plane, jigsaw, etc)
Regards
Phil
Phil P is offline
post #9 of 15 (permalink) Old 04-06-2013, 07:42 PM
post #10 of 15 (permalink) Old 04-07-2013, 12:48 PM
First Name: Bradley
Phil P, seems to work for me. Only offering an option. To each his own...
Fenland Black Oak Table Project-5000 year old tree allbarknobite Lobby 6 10-18-2012 03:21 PM
raised panel oak cabinet doors bobshere Tools and Woodworking 7 01-13-2011 08:43 PM
Red oak or White Oak splinters12 Wood Species 2 09-03-2010 06:38 AM
Mounting an Oak Park Box Jig on Non Oak Park Table challagan Project Plans and How To 55 06-17-2009 10:18 PM
Oak Park table old folks Table-mounted Routing 4 08-07-2007 11:08 AM
