Window hardwear - Router Forums
post #1 of 38 (permalink) Old 11-17-2013, 06:38 AM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Default Window hardwear
I'm searching for window hardwear and specially that part that keeps the window closed. First, what is the correct name for it? The divider is I-shaped. The hindges are on the sides and the window's opens in and out. The divider is betwene inner and outer sils(so we have double glasings). The divider can't be seen from inside. The lowest part of the frame is only on less than 8mm. distance from the Surroundings.
Do you have any idea of a closer that would fit that narrow place?
Esko
My profession is to restore old loghouses that is in the classical way. Look at www.tiny-e.fi and (FB) Tiny-e. Restaurointipalvelut for exaples
Tiny is offline
post #2 of 38 (permalink) Old 11-17-2013, 09:15 AM
First Name: Doug
Send a message via Skype™ to vzbingo
Hi Esko. Just wondering if you have a picture or sketch of your window?
Creator of high grade sawdust and artistic glue spots
"Opportunity is missed by most people because it is dressed in overalls and looks like work." T. Edison
vzbingo is offline
post #3 of 38 (permalink) Old 11-17-2013, 10:52 AM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Shure Doug. Our house is dated back to 1918-1920 and I have never seen window's like this earlier. I would like to find a good looking permanent solution. I thought I might find a satisfying solution here. The counterpart can't be to high because then I can't open the window...
Name:	Keittiön ikkuna pääty.jpg
Esko
Tiny is offline
post #4 of 38 (permalink) Old 11-17-2013, 12:44 PM
Country: Sweden
First Name: mauro
Hej Esko,
maybe i can help you,because i live in Sweden,you should look on this site Eskilstuna Kulturbeslag best place in Scandinavia for classical hardware..or you could check here if you find something..Gysinge centrum för byggnadsvård i didn't get from your message what exactly you are searching for but i hope this could help you..
check this..http://www.kulturbeslag.se/produkter/index.htm
Snickare85 is offline
post #5 of 38 (permalink) Old 11-17-2013, 01:11 PM
Hey, Esko; if I understand you correctly, you have out swinging, side-hung 'awning' sashes on the outside; and inside swinging, side-hung awning style sashes on the inside?
Basically what we'd call storm windows on the outside.
You're looking for locking latches, not closers?
Over here, the old windows had a sliding rod running through a pivoting hub, screwed to the window stooll...the sill being the exterior bottom ledge...which acted as a means of locking the window in any position. This would have been in addition to the actual lever latch.
DaninVan is online now
post #6 of 38 (permalink) Old 11-17-2013, 01:22 PM
Country: Sweden
First Name: mauro
this is quite a modern version of the one used in scandinavia originally Dan,here it is just a eye screw,with a small rod that connect the window casing and the window frame and that lock the windows in place,like you showed in the picture..
post #7 of 38 (permalink) Old 11-17-2013, 02:01 PM
Hi, Mauro; the problem with the lower rod arrangement is that it interferes with the inner sash, if you have inner and outer sashes. That's why I was trying to confirm which mechanism Esko was talking about. I think it might have been the latch on the divider that he meant(?)...
post #8 of 38 (permalink) Old 11-17-2013, 02:10 PM
Country: Sweden
First Name: mauro
Byggfabriken this is what i was talking about..or this..Byggfabriken
post #9 of 38 (permalink) Old 11-17-2013, 03:38 PM
Exactly!
Byggfabriken
But I think Esko meant the latch(?)...
https://www.google.ca/search?q=Casem...iw=950&bih=441
post #10 of 38 (permalink) Old 11-17-2013, 03:43 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Hi Dan.
I'm searchin for a closer. The thing that keeps the inner sill closed until the spring. I tryed to explain The situation with the frames and the part of the window that is not moving, or is a part of the wall. The gap betwene frame and wall is 8mm. Do you understand me? If I open the window there can be something that is only 7mm. high because otherwhy the window wouldn't open. The closer should be made of two pieces of somkind of metal. That part which is atached to the frame can be of normal size but the other part must be very thin because the free hight is only 8mm.
Darn. I check the names for the window part's for to morrow so I can explain what th problem is...
Esko
Tiny is offline
Basement window install. TRN_Diesel Project Plans and How To 11 07-14-2013 09:46 AM
About to attempt first window project, sanity check bobbotron Starting Off 14 08-20-2012 06:56 AM
window project montanaprefinish Table-mounted Routing 5 02-03-2011 02:15 PM
Window Construction jschaben DIY and Renovation 7 12-05-2009 03:13 PM
Window Trim Detail TRN_Diesel Show N' Tell 10 10-23-2009 10:34 PM
