Bedroom furniture - Router Forums
 1Likes
post #1 of 18 (permalink) Old 05-19-2014, 03:22 PM Thread Starter
First Name: Alex
Default Bedroom furniture
Introduction
I present you my project for the construction of bedroom furniture.
I watched as the furniture to suit individual needs:
- Larger storage space (indoor 190x215cm, total size 240x 220cm) and not to waste in outer space (sliding doors).
- Easily removable and mounted in another location (the whole assembly can be mounted with the drawers / shelves on the right).
- Practical and visually pleasing: when you open the room door you donít see just a PAL box like any other cabinets. Shelf area does not prevent the visual field and is based only on the back foot to eliminate any obstacle that you can hit.
- Economical: cheap white PAL is used, doors are made of light wood frame covered in canvas, sliding economical system, we removed the plywood on the back of the cabinet. Cabinet materials cost approx. 200$
You are free to modify the project as you wish, and in the end you will have the satisfaction that from your hands came out an unique furniture.
Tools required
Variable speed drill Electric jig saw Drilling template: used to correct centering holes on the edge of the plate and alignment holes on two different boards.
15mm wood-cutter or cutters set Hand saw Limiting drill and wood drill bits 8,6,4 mm Vices: 3-4pcs
In addition some common hand tools are necessary: square, abrasive paper, and cross screwdriver, hammer, pliers, cutter.
Any construction operations can be done by one person with two hands (but not two "left hands"). Help is needed only at final assembly on position, standing.
For this activity you need a large room (an empty room recommended) that can be easily clean. Cover with foil furniture left in the room (you'll need to for cutting, grinding and making wood powder).
CAUTION: Use protective equipment required for each operation: gloves and goggles (when working with a jig saw). Dust mask (when you wood polished).
Last but not least, if you work in the apartment, respect the rest schedule and not make excessive noise.
AlexWoods is offline
post #2 of 18 (permalink) Old 05-19-2014, 05:29 PM
BCK
First Name: BC
Thanks for sharing........
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #3 of 18 (permalink) Old 04-07-2015, 09:01 AM
First Name: Alana
Originally Posted by AlexWoods View Post
Introduction
Tools required
Tanks for such a hgreat information. I truly lved the furniture image here. The color is so beautiful.
APridham is offline
post #4 of 18 (permalink) Old 04-07-2015, 08:25 PM
Gaffboat's Avatar
First Name: Oliver
+1. I like the color also. Very nice.
Gaffboat is offline
post #5 of 18 (permalink) Old 04-29-2015, 12:01 PM
I'd like to get a new bed for the kids room. Either a double deck or a pull out. What are the advantages and disadvantages of each esp for a small area? around 3m x 3m not including the built in closet?
Wenna Blue is offline
post #6 of 18 (permalink) Old 08-18-2016, 02:11 AM
Beautiful.
PriscillaCNewman is offline
post #7 of 18 (permalink) Old 11-07-2016, 04:48 AM
Good post and very informative
SusanneX16 is offline
post #8 of 18 (permalink) Old 05-02-2017, 01:12 AM
Thanks for sharing @AlexWoods , it is really visually pleasing.
stephentyler is offline
post #9 of 18 (permalink) Old 05-02-2017, 06:53 PM
There is a very modern hotel chain that features simple furniture like this in bold colors. I like the way it looks for awhile, but about 3 days in, I'm tired of it. However, it is a really nice design, and my comment is entirely my personal taste in color.
post #10 of 18 (permalink) Old 05-03-2017, 08:20 PM
MT Stringer's Avatar
Alex hasn't been around since 5/2014. Just sayin'
MT Stringer is offline
G Plan Furniture & Cabinets mattanderson Tools and Woodworking 20 02-10-2012 08:30 PM
Cheap Furniture furnitureinfash New Member Introductions 0 10-18-2010 02:52 AM
I Restore Chinese antique furniture, Tibetan lacquerwares orientantique New Member Introductions 0 05-14-2010 10:55 PM
