Wired Workbench - Router Forums
post #1 of 14 (permalink) Old 03-01-2015, 10:12 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Wired Workbench
I'm sure some of you will be able to relate . . . . I'm about 20% done with kitchen cabinets that will take six months of nights and weekends if I'm lucky. I was sanding away with three different sanders plugged into the overhead cord reel that has been good enough for 15 years. Suddenly, the swinging tangled cords were just too distracting from the task at hand. Then and there, I decided that I simply must have receptacles on three legs of my workbench.
The cabinets are forgotten and it's off to the big box store for electrical supplies. Then it's crawling on my belly in the dirt under my shop to run a wire from the breaker box to a hole I drilled in the floor at the foot of my workbench. The store-bought fittings just wouldn't suffice, so I had to heat the PVC conduit and bend it to get to the receptacles. Then, it's back on my belly under the shop to retrieve the wire I allowed to drop back through the hole. The wire was difficult to pull through the tortuous compound bends of the conduit, but I got it done. Finally, after spending most of the weekend on electrical work, I got it all connected up and no sparks flew when I flipped the breaker. I'm sure I'll enjoy having electricity close at hand, but right now, I'm somewhat annoyed with myself that I "wasted" most of the weekend feathering the nest instead of pursuing the task at hand.
Anybody else have this problem?
DonkeyHody is offline
post #2 of 14 (permalink) Old 03-01-2015, 10:30 PM
jj777746's Avatar
Andy,look at it this way,you may have saved yourself or someone else from being electrocuted,judging by the description of your previous wiring set-up.Nice work & well worth the time spent. Jim.jj777746
jj777746 is offline
post #3 of 14 (permalink) Old 03-01-2015, 10:50 PM
nice work...
next time use MC cable and you'll save a bunch of time and your life will get easier...
AFC Cable Systems 100 ft. 12-2 Solid MC Lite Cable-2104S30-AFC - The Home Depot
post #4 of 14 (permalink) Old 03-01-2015, 10:52 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Nah, the overhead cord reel is safe enough. It's a receptacle block hanging from a retractable reel protected by an additional circuit breaker in the reel itself. It just got annoying having the thing swinging around all the time, and the cord for the tool itself always seemed to end up in the way on the workbench. This way, the cord ends up looping toward the floor instead of piling up on the bench. It just seems sometimes that I spend more time working ON the shop than working IN the shop.
post #5 of 14 (permalink) Old 03-01-2015, 10:57 PM Thread Starter
DonkeyHody's Avatar
First Name: Andy
nice work...
Ah, but you don't know me that well . . .
I considered it, but I'm too anal to go the easy route. It had to be all "buttoned up" for reasons I can't explain. Sometimes I make things harder than they need to be.
post #6 of 14 (permalink) Old 03-02-2015, 01:10 AM
From one anallitic guy to another...
keep seal tite in mind the next time around.
post #7 of 14 (permalink) Old 03-02-2015, 05:32 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
(Palm to Forehead) NOW you tell me!
post #8 of 14 (permalink) Old 03-02-2015, 05:46 AM
but you didn't ask....
post #9 of 14 (permalink) Old 03-02-2015, 08:49 AM
Country: South Africa
First Name: Ronald
Problem? What problem. I thought it was a universal trait.
Ronald
Mistakes are proof that I am trying....
Now to remember what!
swarfmaker is offline
post #10 of 14 (permalink) Old 03-02-2015, 01:45 PM
First Name: Ray
I have always known that flexible cable as "BX" cable when it had wires in it and "Greenfield" when it was empty cable.
RMIGHTY1<==== also anal.
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
My first Workbench Burke Show N' Tell 11 10-15-2011 10:25 PM
Half Blind Dovetails for a Workbench kbiniowa Tools and Woodworking 5 04-23-2011 08:16 PM
Workbench / Router table Jusaquikie Table-mounted Routing 14 03-15-2011 10:19 AM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 02:54 PM
Workbench Pictures -Sam- Show N' Tell 22 09-16-2009 07:11 PM
