How they fastened build my 1970's counter top - Router Forums
 7Likes
  • 3 Post By Marco
  • 3 Post By DaninVan
  • 1 Post By MT Stringer
post #1 of 7 (permalink) Old 03-19-2015, 08:58 PM Thread Starter
Marco's Avatar
Default How they fastened build my 1970's counter top
I recently asked in a thread "How did they fasten old countertops" . Thanks again for all of the tips/suggestions and links as I was able to save the base cabinets while removing the tops.
My cabinets that had formica backsplash were surprisingly fastened to the cabinets with a few screws. I initially didn't see the screws. The tops edges were nailed to the top from the side and the backsplash was nailed to the top from the bottom. Fortunately no glue was used except a few drops where the top and edge met.
MT Stringer, jj777746 and APridham like this.
Galatians 5:13
Marco is offline
post #2 of 7 (permalink) Old 03-19-2015, 09:52 PM
good.. ya lucked out...
post #3 of 7 (permalink) Old 03-19-2015, 10:19 PM
Good work Jim.
post #4 of 7 (permalink) Old 03-20-2015, 05:23 PM
Nickp's Avatar
First Name: Nick
Phew...! ! !
Nick
Nickp is offline
post #5 of 7 (permalink) Old 04-07-2015, 07:59 AM
First Name: Alana
It really sounds great. But is it durable?
APridham is offline
post #6 of 7 (permalink) Old 04-07-2015, 10:45 AM
Hi, Alana; flat application High Pressure Plastic Laminate, HPL, has been around since at least the '50s. It tends to either wear through the pattern or lift when the contact cement dries out and discombobulates. The most common visual defect is broken edges from abuse.
Is it durable? You'll get tired of looking at it long before the stuff craps out.
DaninVan is offline
post #7 of 7 (permalink) Old 04-07-2015, 12:02 PM
MT Stringer's Avatar
Just before it goes into the dumpster, cut off a piece to make a router table.
Cherryville Chuck likes this.
MT Stringer is online now
How to best attach router table top to cabinet? xvimbi Table-mounted Routing 3 05-28-2010 07:30 AM
Table Top... Build or buy? centex99 Table-mounted Routing 31 03-10-2009 12:39 PM
Build a Router Table Top twhited Table-mounted Routing 4 08-06-2008 04:33 AM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 08:00 AM
