How to cut glass - Router Forums
 2Likes
  • 1 Post By Stick486
  • 1 Post By Gaffboat
post #1 of 10 (permalink) Old 04-24-2015, 06:37 AM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Default How to cut glass
Hi everybody. Generally I know how to cut glass but If its only 1/4" you have to cut how should it be done?
Esko
My profession is to restore old loghouses that is in the classical way. Look at www.tiny-e.fi and (FB) Tiny-e. Restaurointipalvelut for exaples
Tiny is offline
post #2 of 10 (permalink) Old 04-24-2015, 06:43 AM
how big of pieces...
good video...
but what the guy does w/ his gizmo you do w/ the ball end of the glass cuter...
jj777746 likes this.
post #3 of 10 (permalink) Old 04-24-2015, 08:39 AM
Cuts that narrow are really hard to do Esko. I've tried a few times but my failure rate exceeds my success rate. Use a new cutting wheel for starters. I've tried putting the pane on something like a ruler with the score line just over the edge and placing a board on the piece to be broken off and tapping it with a hammer. That improved my success rate but is still not perfect. Although that method works very well for cutting floor tiles. Maybe someone has a better method.
post #4 of 10 (permalink) Old 04-24-2015, 11:09 AM
Gaffboat's Avatar
First Name: Oliver
You might want to try using glass breaking pliers which are an important tool in making stained glass projects. Here's a video showing how they are used.
Gaffboat is offline
post #5 of 10 (permalink) Old 04-24-2015, 11:14 AM
Esko; Good to hear from you again!
DaninVan is online now
post #6 of 10 (permalink) Old 04-25-2015, 07:17 AM
First Name: Art
Cut using a straight edge then knock the back of the cut with the end of the cutter to make it crack completely through. The cutter will usually have a a small ball shape on the end to act like a hammer head. Also be sure to use oil on the cutter head never do it dry.
mgmine is offline
post #7 of 10 (permalink) Old 04-25-2015, 01:47 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
Thank's guys! I'll try your tips first thing on monday! I knew I can get the info from you, everything I always wanted to know about life universe and everything but were afraid to ask.
Tiny is offline
post #8 of 10 (permalink) Old 04-25-2015, 01:48 PM Thread Starter
Tiny's Avatar
Country: Finland
First Name: Esko
PS. Nice to be back
Tiny is offline
post #9 of 10 (permalink) Old 04-29-2015, 10:59 AM
I'm surprised the person in the video is not wearing any type of protective gloves. I use it all the time since I have cut myself a lot. I use the glass cutter and pliers for my stained glass projects too.
Wenna Blue is offline
post #10 of 10 (permalink) Old 08-18-2016, 01:08 AM
Good suggestion
PriscillaCNewman is offline
Shooting Board vs. Incra Miter Gauge. Jerry Bowen Tools and Woodworking 26 01-08-2014 03:33 PM
Lets make a Jewlery Case neville9999 General Routing 1 11-21-2013 07:06 PM
How to cut slots in 2 pieces that are not straight on outsides. Midnight Shadow General Routing 4 07-26-2010 11:04 AM
Spiral or Double Fluted straight bits for this cut? 6f6 Router Bits - Types and Usage 1 06-28-2010 10:15 PM
Up Cut... Down Cut... Joe Lyddon Router Bits - Types and Usage 2 09-10-2006 06:21 PM
