Rust removal electrolysis, how to remove black - Router Forums
 5Likes
  • 1 Post By DaninVan
  • 1 Post By smitty10101
  • 2 Post By schnewj
post #1 of 10 (permalink) Old 06-05-2015, 04:40 PM Thread Starter
Country: Poland
First Name: Dominik
Default Rust removal electrolysis, how to remove black
Hi.
I start restore bench saw and use electrolysis.
Now I have black oxidation or something....
How to remove it ? I have parts in complex shapes threats gears and I can't sanded it.
DominikPierog is offline
post #2 of 10 (permalink) Old 06-05-2015, 06:23 PM
Phosphoric acid, Dominik. Should remove it completely, but you'll have to coat the steel right after as it will just flash rust again.
Herb Stoops likes this.
DaninVan is online now
post #3 of 10 (permalink) Old 06-05-2015, 07:33 PM
First Name: Mark
I used just a detergent soap and a brush. It should come off fairly easily
FreeTime is offline
post #4 of 10 (permalink) Old 06-05-2015, 11:23 PM
I knew there was something, couldn't remember what it was, kept thinking of vinegar or lemon juice. Both wrong.
Herb Stoops is online now
post #5 of 10 (permalink) Old 06-06-2015, 09:07 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
vinegar (maybe lemon juice) will remove the rust---eventually.
I'm soaking some tools right now to compare against Evapo-rust.
I tried the electrolysis--it works but had to do it in the shed away from ignition source.
Also was limited to quantity of stuff to be done at one time so I found that the Evapo-rust was a time saver
With the black "patina" that was left from the electrolysis--I just gave the stuff a quick water bath and then just wiped it down. Anything that couldn't be reached with the cloth got a compressed air spray until dry.
smitty10101 is offline
post #6 of 10 (permalink) Old 06-06-2015, 01:42 PM
Dominik; how about using your tumbler and something like walnut shells or sand blast grit? Should come out immaculate.
post #7 of 10 (permalink) Old 06-06-2015, 03:18 PM
I think he is talking about his table saw, Dan. Sand blasting would work ,have to protect the bearings in the arbor from the grit. Can walnut shells be used in sandblasting too?
post #8 of 10 (permalink) Old 06-06-2015, 07:17 PM
schnewj's Avatar
Herb,
Absolutely! Walnut hulls, glass beads, corncob, baking soda, and in some cases lead or steel shot can all be used to blast. Depends upon the material being blasted. Example; baking soda will blast off paint and not hurt plastics, like tail light lenses. I believe walnut will do the same, but is a little more aggressive.
Bill
Herb Stoops and stephentyler like this.
schnewj is offline
post #9 of 10 (permalink) Old 06-06-2015, 07:34 PM
I thought Dominik had disassembled it? How else could he have done the electrolysis?
I agree putting all the heavy parts in the mixer at one time would not be a great idea...
post #10 of 10 (permalink) Old 06-07-2015, 12:27 AM
You are probably right ,Dan. I have never removed rust that way, so didn't think of that.
Rust Removal From My Table Saw TOP Tagwatts1 Tools and Woodworking 68 03-28-2016 06:12 PM
Electrolysis rust removal example GulfcoastGuy Tools and Woodworking 10 10-20-2013 09:28 AM
Rust removal on table saw luvmyretirement Tools and Woodworking 62 10-04-2009 06:58 PM
