Bath Vanity Mod - Router Forums
 16Likes
post #1 of 14 (permalink) Old 10-20-2015, 11:30 PM Thread Starter
MT Stringer's Avatar
Default Bath Vanity Mod
I decided our vanity needs more drawers!
The two top drawers were in actuality just false fronts nailed to the carcase from the inside. This was so a counter top with dual sinks could be used. But we opted for a top with a single sink.
I removed the fronts, and installed some spacers in the rear so the rear brackets for the drawer tracks can be attached.
Hopefully tomorrow I will get the drawer boxes built. The weather has turned crummy so spraying outside is cancelled for now.
Here's a couple of pics of the progress so far.
Name:	2015-10-20 10.01.17.jpg
Name:	2015-10-20 10.01.06.jpg
MT Stringer is offline
post #2 of 14 (permalink) Old 10-20-2015, 11:44 PM
RainMan 2.0's Avatar
Good thinking Mike . I was going to see if I have enough clearance to install a power outlet in the back of my top drawer. Not sure how easily it will slide with 14 gauge wire going to it though
MT Stringer likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 14 (permalink) Old 10-21-2015, 01:30 AM
Default ??????
You sure the welder will fit?
Roy Drake, Murtu01 and Herb Stoops like this.
DaninVan is offline
post #4 of 14 (permalink) Old 10-21-2015, 08:23 AM
You can't use Nomex or Romex or whatever we have these days Rick. It's not designed to flex that much or that many times. You would have to install an outlet in the wall behind and then run stranded extension cord type wire to a box in the back of the drawer. And to be up to code it would have to a GFCI plug or GFI breaker in the panel.
post #5 of 14 (permalink) Old 10-21-2015, 08:33 AM
I was thinking the same thing Charles , run a more flexible wire off the gfi to a box
post #6 of 14 (permalink) Old 10-21-2015, 07:55 PM
C'mon Mike. Admit it. You were just looking for another project, now that the kitchen remodel is almost done......VBG.
Sydney, Australia
jw2170 is offline
post #7 of 14 (permalink) Old 10-21-2015, 10:09 PM Thread Starter
This drawer building stuff is getting easy.
Name:	2015-10-21 15.47.02.jpg
Name:	2015-10-21 16.02.56.jpg
RainMan 2.0 likes this.
post #8 of 14 (permalink) Old 10-21-2015, 10:28 PM
MEBCWD's Avatar
Mike my question is "where do you find all the time for the projects you do?".
MEBCWD is offline
post #9 of 14 (permalink) Old 10-21-2015, 11:09 PM Thread Starter
Well, I'm retired so I am not on any sort of clock or schedule. I can't just sit around and get rusty!
And when I get on a roll, I get several things going at once. My laptop is doing it's first full backup. I have my wife's old laptop that I am swapping out hard drives. And tonight, I fired up Chromecast via ipad, and watched 30 plus You Tube videos on the big screen TV! I like that.
I will probably sleep late and then start all over again tomorrow. The drawers fit like a glove so tomorrow I need to go find a couple of knobs and install the drawer fronts, and that little mod will be complete.
jw2170 and papasombre like this.
post #10 of 14 (permalink) Old 10-23-2015, 04:45 PM Thread Starter
Done deal. Already moved in!
Name:	2015-10-23 15.27.30.jpg
Name:	2015-10-23 15.27.44.jpg
Name:	2015-10-23 15.27.55.jpg
Name:	2015-10-23 15.29.58.jpg
jw2170, TenGees, old55 and 2 others like this.
Vanity Vanity; All is Vanity DonkeyHody Show N' Tell 30 02-14-2015 07:50 PM
What color tile and paint for bath? TramondKrick Wood Species 11 08-10-2012 01:20 AM
2x30" bathroom vanity? quantumburnz DIY and Renovation 5 03-06-2010 02:30 AM
Bathroom vanity redo lrr Show N' Tell 2 12-13-2006 07:46 PM
