Router Forums (https://www.routerforums.com/forum.php)
-   DIY and Renovation (https://www.routerforums.com/diy-renovation/)
-   -   Another Vanity. (https://www.routerforums.com/diy-renovation/91225-another-vanity.html)
Stick486 03-24-2016 08:10 PM
very nice work...
tomp913 03-24-2016 09:48 PM
1 Attachment(s)
Originally Posted by jd99 (Post 1130545)
I'm probably going to go with white Formica, I priced getting a counter top made, but because its an odd shape, they want $125.00 to start that's before the cost of material, and labor is figured in.
Ill make one myself, it wont have the fancy edge, I'm thinking of getting some exotic wood, and routing an edge detail on it and using that for the edge.
An Roman Ogee bit with the step set at the bottom of the laminate makes a nice edge detail.
jd99 03-26-2016 12:50 PM
I think I found the answer to my countertop edging dilemma.
There is formica edging that can be installed. has anyone used this fromica edging? If so how was it is it as easy as they show in this video?
jd99 03-30-2016 12:17 AM
2 Attachment(s)
Got some more time to work on the vanity today, got the face frames all installed.
Next I got to get busy and make the drawers.
Stick486 03-30-2016 12:33 AM
you do some very nice detailed work Danny..
jd99 04-04-2016 09:32 PM
1 Attachment(s)
Did some more work today, got the drawer parts all cut, and the dovetails all done, tomorrow Ill glue them together. Then start on drawer fronts, and doors.
jd99 04-11-2016 07:34 PM
1 Attachment(s)
Drawer fronts and Doors all done, ready to drill for hinges, then mount on vanity, and check for fit and finish. Then Sanding and painting.
Every woodworkers joy..... Sanding :sarcastic:
wags999 04-11-2016 07:55 PM
[quote=jd99;1136033]I think I found the answer to my countertop edging dilemma.
To answer your question yes, it's not difficult at all. I did literally thousands of feet of this edging before WilsonArt purchased them, and after they purchased them. Before we could get any brand laminate, after, only WA. I would suggest using the tongue one as it's easy to line it up once and your good, also more glue surface. I actually worked with the old owner on the sander. Nice machine which I used for years and years, wish I still had it . It does make a nice edge. The bevel is what they started out with and we later went to making our own bevel edge style laminate edges. Does make a nice top. You can also get the laminate up to 60" wide by 144" long so, depending on what you choose you may be able to make the deck with no seams. Good luck !
It is WilsonArt not Formica laminate so.....
jd99 04-11-2016 08:08 PM
[quote=wags999;1155450]
Thanks Tom.
FYI I was considering using the edging that has the tongue, I figured it would help with holding the alignment, along with more glue surface.
jd99 04-17-2016 02:58 PM
Finally!!!
2 Attachment(s)
Finally got a chance to mount all the drawer fronts and doors to check for fit.
I got a couple of small things to do, but now I can go ahead and spray the drawer fronts and doors with sealer and get them ready to shoot the color.
Top view shows how the sink section is 45 degree instead of a 90 degree L shape. (There's a reason for this, I'll show later).
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
