Basement Remodel - Router Forums
 12Likes
post #1 of 17 (permalink) Old 04-11-2016, 02:53 PM Thread Starter
berry's Avatar
First Name: Berry
Default Basement Remodel
We're doing a basement remodel, about 400 sf. It's been almost 25 years since the last one. I have a number of questions and I'm hoping some of the regulars here will do these jobs professionally and be able to offer some tips.
Ceiling: Like many home our ceiling is suspended and we have 2 x 4 panels of some lightweight material. We're hoping to find some way to capture the 2-3 inches of suspension with some system. My wife wants something with 'character'. And we'll need access to some portions of the ceiling, water shut-offs etc. ????
Floor: We've had carpeting down but I'm wondering about using Dri core or a similar product to isolate the concrete from the floor we'll walk on. I've seen folks put down boards and then spray that expanding foam between each board. ????
Fireplace We are have a gas fireplace installed and I thought I'd make the surround, I have a ton of cherry in the garage. Cautions, design ideas,
Thanks for reading.
May the grain be ever in your favor.
berry is offline
post #2 of 17 (permalink) Old 04-11-2016, 03:01 PM
what are the questions...
post #3 of 17 (permalink) Old 04-11-2016, 07:11 PM
Berry the Dri-core is great stuff. It would work good in you situation. Easy to install too.
As far as the ceiling goes, is the ceiling lowered to conceal the pipes or duct work? If you didn't want a ceiling that is the same elevation throughout, you can keep it lowered where required and eliminate it elsewhere. Remember tho that wiring and such will then have to be run thru the joist. You could then either nail the ceiling to the joist bottoms or install furring strips crosswise of the joist direction. You could put some false cherry beams across the ceiling too.
A cherry surround would look great around the fireplace. You might want a ceramic or masoary hearth to compliment the fireplace too.
You got some work ahead of you. good luck, be sure to show progress photos.
berry and Roy Drake like this.
Herb Stoops is online now
post #4 of 17 (permalink) Old 04-11-2016, 08:05 PM
Nickp's Avatar
First Name: Nick
CEILING:
As Herb already pointed out, the dropped ceiling is likely to have been installed to hide all the wires and plumbing and to provide access to same. Replacing with sheetrock or the like will cause you to provide the same function. You may even find that the joists are not exactly even and so the sheetrock will appear "wavy". You will also need to deal with providing access to necessary controls...may be a problem depending on how many access points you need. You might need to rewire, drill into joists, re-do the piping, etc... And then framing around ducting...? Consider also the maintainability of your future lighting... Dropped ceiling will provide you with better "future-proofing", for example, cable TV wires, new electric, different lighting, additional ducting, etc... Is it worth the 2-3 inches...? dunno...you'll need to plan and design carefully to give yourself the same flexibility of a dropped ceiling.
FLOOR:
Good stuff, I understand... Is the concrete level...? Low/high spots...? Consider also tiles, carpet...? As for the expansion foam between boards, dunno 'bout that... I would also consider some kind of water/moisture proofing if you do tiles or carpet...DRY-LOCK comes to mind. You would likely need a bonding agent if doing tiles...WELDCRETE, for example...
FIREPLACE:
Great idea...should look nice. I would suggest Google'ing some images for ideas. Do you have the tools to do the job...? Router, bits, table saw, planer, dust collection, place to do the work, etc... Consider if you want it to be functional...code, distances to walls, clear chimney, dampers...then, insert or as is...? Do you need it to provide heat...insert with fan...?
Sounds like a fun project but definitely lots of work.
Is this a semblance of what you were looking for...? I'm sure you'll get lots more ideas from others...
Nick
Nickp is online now
post #5 of 17 (permalink) Old 04-11-2016, 08:56 PM
Hey, Berry; is Radon gas an issue in your region? Certainly a consideration when doing a bsmt. reno.
DaninVan is offline
post #6 of 17 (permalink) Old 04-11-2016, 09:06 PM
OttoW's Avatar
First Name: Otto
How about some pictures of the space so we can get an idea of what your thinking of.
New guy looking for ideas.
OttoW is offline
post #7 of 17 (permalink) Old 04-11-2016, 09:38 PM Thread Starter
berry's Avatar
First Name: Berry
Does anyone have a flooring or ceiling system they'd recommend? Does anyone have fireplace experience they'd be willing to share as I move into design and construction.
berry is offline
post #8 of 17 (permalink) Old 04-11-2016, 09:40 PM Thread Starter
berry's Avatar
First Name: Berry
It is and we have a outfit coming in to run the tests soon.
DaninVan and Roy Drake like this.
berry is offline
post #9 of 17 (permalink) Old 04-11-2016, 09:53 PM
insulate and rock the ceiling...
access door where the shutoffs, clean-outs and traps are..
dricore on the floors...
rocked over Z metal and polystyrene on the walls...
go with “Z” channel and capture the foam board and make life easier on yourself...
Foam board and "Z" channel is installed horizontally...
http://www.clarkdietrich.com/product...urring-channel
W/ the "Z" metal being horizontal you can hang the rock vertically which eliminates butt joints and reduces waste... Saves on mudding also..
berry likes this.
post #10 of 17 (permalink) Old 04-12-2016, 05:19 AM
skiroy56's Avatar
First Name: Laurence
For the floor in my wife's basement studio I installed treated 2x4 sleepers screwed to the concrete. Then installed styrofoam insulation between, covered with a layer of thick poly and screwed plywood subfloor on that. Finally we installed laminate flooring on top and she is very happy and pleased with that. The ceiling is a suspended ceiling as there is ductwork, plumbing and wiring overhead. The walls are sheetrock painted.
This has made her a very bright and comfortable studio to work and quilt in.
Happy wife Happy life!
berry and Herb Stoops like this.
skiroy56 is offline
Basement cabinet for gun safe DelDave61 New Member Introductions 60 11-26-2014 07:41 PM
Garage vs. Basement for my Shop the202 DIY and Renovation 17 07-30-2011 03:34 PM
Basement build out tobad DIY and Renovation 14 03-17-2010 10:55 AM
Moving the shop from garage to basement xplorx4 Jerry Gould 182 08-22-2009 05:52 AM
