Here's an update of my deck project - Router Forums
 16Likes
post #1 of 11 (permalink) Old 04-25-2016, 08:43 PM Thread Starter
bryansong's Avatar
First Name: bryan
Default Here's an update of my deck project
I've been busy building my two new decks. I also replaced a door on the side of the house where the smaller deck was added.
Up next I'll be ordering building materials for the roof structure for the large deck at the rear of the house. I'm also trying to figure out what kind of skirting I'd like. It'll probably be vertical boards but I'll have to work around all of the piering.
You can also see all of the concrete work I've hired completed.
That darn cat!
JFPNCM, billyjim, marecat3 and 5 others like this.
bryansong is offline
post #2 of 11 (permalink) Old 04-25-2016, 09:07 PM
Nickp's Avatar
First Name: Nick
Very nice...you've been busy !
You might consider lattice cut/shaped to your liking..they also make white plastic with thin and thick lattice work...might look nice with the white trim on the house...
Good luck...looks real good...
Nick
Nickp is online now
post #3 of 11 (permalink) Old 04-25-2016, 10:30 PM
RainMan 2.0's Avatar
Wow you've been a busy man . Once the landscaping is done it's going to look fantastic.
There must be 20 lawn chairs there . You must have a lot of friends that want to celebrate on the new deck
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 11 (permalink) Old 04-25-2016, 10:43 PM Thread Starter
bryansong's Avatar
First Name: bryan
About the lawn chairs, I had to get the deck to at least this level because last Saturday, two days ago, our house was the
venue for our future daughter-in-law's bridal shower. They did set up tables on the deck. I went to Lowes a couple of days before and bought chairs.
I watched the grandchildren inside the house while all of the women had their shower. Success!
Roy Drake likes this.
post #5 of 11 (permalink) Old 04-26-2016, 03:02 AM
nice build Bran...
lattice for the open space...
leave the CC footers exposed as much as possible and veneer them w/ brick, stucco, stone or stain them...
next time set the piers back from the deck's rim and do cantilever construction,,
Stick486 is offline
post #6 of 11 (permalink) Old 04-26-2016, 07:54 AM Thread Starter
bryansong's Avatar
First Name: bryan
nice build Bran...
Not knowing any better I now would have preferred to have the CC end close to the ground but since I didn't think about that when they were poured I'll have to work around it. Oh well, live and learn.
The main reason for the piers being so far out at the end is because I will have 4 8" columns that support a roof.
I think your veneer idea is a good one.
post #7 of 11 (permalink) Old 04-26-2016, 10:44 AM
JFPNCM's Avatar
First Name: Jon
Well done and just in time for a big event as well. Agree with the lattice and veneer approach.
One comment on the plastic lattice if it exposed to hot sun for long periods it will expand and buckle a bit but it does recover. Given the width of your sections however I doubt that will be an issue especially if the framing allows for a bit of expansion. .
Jon
JFPNCM is offline
post #8 of 11 (permalink) Old 04-26-2016, 06:55 PM
Nice job Bryan. I like the lattice work idea. Air flow can't hurt and it always looks so nice. The roof over the deck also seems like a good idea. Don't know if you have mosquitos or other bugs to deal with, but later, you can screen in the porch or even put up windows. Our patio room is really nice to have and gives my wife a place to paint.
post #9 of 11 (permalink) Old 04-26-2016, 07:54 PM
vchiarelli's Avatar
First Name: Vince
Bryan
Nice job on the deck - I especially like the interlock patio with the "easy bake oven" in the corner.
I've never been a fan of lattice to close in the bottom of the deck. When I had my deck re-done last fall, using a composite material, I used the same material, vertically, to close in the bottom, but my deck was a bit higher off the ground than yours.
With the height of your deck, I'd be tempted, on the side next to the poured cement walkway, to build a full-length step (or two) depending on the height off the ground. Then on the front on each side of the step and on the right hand side (opposite the walkway), I'd put in some low shrubs to cover the space. Just a thought.
bryansong likes this.
vchiarelli is offline
post #10 of 11 (permalink) Old 04-26-2016, 08:32 PM
Lattice doesn't seem to be "in" these days, only see five in all these decks.
https://duckduckgo.com/?q=Sun+deck+s...ax=1&ia=images
I think I see yours in here Vince.
Herb Stoops is offline
Windows 10 install review kp91 Lobby 176 07-24-2016 09:45 AM
Windows 10 coming to your PC ... Stick486 Lobby 68 06-28-2016 10:43 PM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
