Idea for workbench modification - Router Forums
 28Likes
post #1 of 20 (permalink) Old 06-13-2016, 04:36 AM Thread Starter
Tommy Law's Avatar
First Name: Tommy
Send a message via MSN to Tommy Law Send a message via Yahoo to Tommy Law
Default Idea for workbench modification
I have a Craftsman 6' workbench that I havent really used for much more than a Big A$$ shelf since I got it. I've been trying to organize my work area for some time now and have come up with a few ideas for the bench. Any feedback or suggestions are welcome, here are soem of my ideas for now.
1) Removing it from the base and turning into a folding bench. It would create more space for the stuff that gets stored in there that I remove to do work, but I foresee hassle of clearing the room wen want to fold it up. Cannot be stored folded up since it is below a window.
2) I think is my most likely idea. Make one end a router station. Mount my Dovetail jig onto a folding wing and either get a Router plate/lift to mount router into bench eliminating need for the portable cheap table I have. I also want to incorporate a t-track and/or bench dog holes to allow clamping capabilities not currently available. I also want to add a set of shelves under the bench similar to the Modular ones already available from Sears for $90.00 or so without buying them since funds are limited. I have scrap metal I plan to use already a couple old retail display shelves are the sacrificial canidates for this.
3)Making it into 2 smaller work tops. Not real sure how I'd want to do it but would require reworking the base. Not too keen on this one it was just a thought figured I would throw it out there.
Some point in the future I do want to add a stainless/or metal top to all or part for welding.
Tommy Baltimore
"To alcohol...The cause of and answer to most of life's problems!" H. Simpson
Tommy Law is offline
post #2 of 20 (permalink) Old 06-13-2016, 05:17 AM
make the legs fold up and attach/hinge the top to the wall...
post #3 of 20 (permalink) Old 06-13-2016, 06:29 AM Thread Starter
Tommy Law's Avatar
First Name: Tommy
Sears.comthat is the bench I have. If I do the folding legs I need to re work them a little then theres the issue I know I will have that I pile everything in front of it so it gets buried. My shed/ shop is maybe 11'x11'. I would love to use it it just has been the catch all for anything smaller. Im trying to slowly fix that issue with making wall storage.
Tommy Baltimore
post #4 of 20 (permalink) Old 06-13-2016, 07:10 AM
wanna conserve a boat load of space...
make sliding door cabs ...
use the base as a service trunk...
use the doors as wall space...
set the table out where you can work on it...
this satellite shop is one foot smaller than your shed and it has a TS, BS and a BMW touting bike in it...
plan...
Name:	2ND DOOR OPEN.jpg
Name:	CLAMP RACK 1.jpg
post #5 of 20 (permalink) Old 06-13-2016, 02:23 PM
Gaffboat's Avatar
First Name: Oliver
I think Stick nailed it. The three most important parts of any shop are: storage, storage, storage. Stuff always piles up when it doesn't have a real home. Your projects become easier when you add effective storage because you always know where to reach for something when you need it, and return it to its home when you're done with it. I'm guilty of letting stuff pile up also and it's a constant battle to keep the bench clear. Especially for those of us who save everything.
Gaffboat is offline
post #6 of 20 (permalink) Old 06-13-2016, 02:33 PM
Nickp's Avatar
First Name: Nick
Exactly right...it will get in the way just to fold it...
I think the top is too thick and probably too high...shelves and drawers underneath it is much better idea. If it's too tall, shorten the legs, then add shelf on bottom or use the space underneath for storage (like Stick proposed)...
Naah...
Be careful you don't try to do too much with it...prioritize...what do you need and how big a worktop do you need to work on...
I put my workbench against the wall, shelves underneath for storage then changed to half drawers and half shelves...it's still against the wall, out of the way and every once in a while I have to do a major clean up to stow the junk on the surface...small price to pay...
DaninVan, Stick486 and Tommy Law like this.
Nick
Nickp is offline
post #7 of 20 (permalink) Old 06-13-2016, 03:35 PM
MT Stringer's Avatar
I skipped over most of the replies because I wanted to say I like idea #2. Why, you might ask? Well, it is because my workbench is sorta related to your bench.
I built it out of construction grade lumber and used a solid core door for the top. It has dog holes and Kreg Klamp tracks. The top is covered with Formica so the glue doesn't stick.
If you peruse my projects and threads I have started, you will see that workbench in a lot of those project pics.
A router on one end and Klamp Tracks on the other should make a very handy work bench you will get a lot of use out of. You can trust me on that. I have lost count on the number of face frames, doors and drawers I have built using that bench, clamps and tracks over the last few years.
Note: Check out the drawer on wheels I made to store clamps under the bench. You could build something like that to fit under your bench frame.
Good luck.
Name:	2013-09-19 12.51.39.jpg
Name:	2014-02-04 11.28.38.jpg
Name:	2013-08-24 17.54.55.jpg
Name:	2014-06-24 14.18.17.jpg
Name:	2014-06-29 14.18.03.jpg
MT Stringer is offline
post #8 of 20 (permalink) Old 06-13-2016, 04:43 PM Thread Starter
Tommy Law's Avatar
First Name: Tommy
plan...
Thats what I'm thinking however I lose a lot of wall space due to windows at 4'6" to bottom in center of 2 walls and they are 30" wide and 2' tall thats a lot of wall space I'd kill to have back. On top of the woodworking stuff I also have 2 gangboxes for my Electrical tools that I just got on wheels to help with mobility. I think im going with #2 I'6'1 tall so the height isnt too bad if need be ill make a step box or something.
Tommy Baltimore
post #9 of 20 (permalink) Old 06-13-2016, 04:45 PM Thread Starter
Tommy Law's Avatar
First Name: Tommy
MT I wish I could have mine in middle of space like yours bc I already was thinking TS use but no can do. As far as the depth of my top I was thinking of taking the Table its on now taking its little top using it as a plate and cutting out space in top to drop it in
Tommy Baltimore
post #10 of 20 (permalink) Old 06-13-2016, 06:29 PM
Most of the router plates require a 3/8 inch recess for the plate to drop in. A lip all around is all that is needed, the middle can be cut away. For your top, you might need to add additional support underneath so the whole thing doesn't sag.
Good luck. Remodeling your bench could be fun.
Modification Of Jerry's Unpopular New Idea Jerry Bowen Tools and Woodworking 33 04-15-2013 09:55 AM
Help with my Bed Idea FordTrax General Routing 12 11-27-2012 06:46 PM
I Have An Idea Jerry Bowen Tools and Woodworking 5 06-19-2012 04:06 PM
New Forum Organization Idea Mark Site Help and Suggestions 55 11-11-2008 12:57 PM
An idea.... Mark The Voting Booth 3 08-25-2006 03:53 PM
