Wooden rings - Router Forums
 4Likes
  • 3 Post By papasombre
  • 1 Post By papasombre
post #1 of 8 (permalink) Old 06-19-2016, 08:15 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Default Wooden rings
Hi, guys.
I am starting a new project never the less I have a lot of them under progress.
Now I want to make several curtains poles for the windows. Since the prices in the decoration stores are out of my budget I started it by making the wooden rings to hang the drapery. This is the first time I used my new drill press attached to the base I recently posted.
As usual, no milestone so I don´t know when this project will be finished.
We, woodworkers are everywhere!!!
papasombre is offline
post #2 of 8 (permalink) Old 06-19-2016, 08:19 AM
well done Alexis..
Stick486 is offline
post #3 of 8 (permalink) Old 06-19-2016, 08:28 AM
Gene Howe's Avatar
First Name: Gene
Great use of materials. I like those curtain rings and, the way you clamped them for the last cuts.
Just a thought...you might've reduced the diameter of the sanding drum and used it to sand the insides of the rings.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #4 of 8 (permalink) Old 06-19-2016, 08:44 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Gene.
At picture 13 you can see a small taper in the drum. I forgot to write about it.
BTW, Happy father day!!! At least here, nothing to celebrate...
Gene Howe likes this.
post #5 of 8 (permalink) Old 06-19-2016, 09:45 AM
Gene Howe's Avatar
First Name: Gene
Oops, I missed that.
Hey, you are welcome to celebrate with us. The more the merrier.
Originally Posted by papasombre View Post
Hi, Gene.
Gene Howe
Snowflake, AZ
post #6 of 8 (permalink) Old 06-19-2016, 09:49 AM
Very clever Alexis.
post #7 of 8 (permalink) Old 06-19-2016, 12:52 PM
I made some similar rings (not as fancy though, used scrap plywood) and used a heel clamp to hold the ring while boring the inside hole.
To add a radius to the edges, I used a variation on a method described by Harry Sinclair, but with double ended finish nails driven into the ends of short pieces of dowel, the dowels set into a piece of plywood with a hole pattern to suit the size of the rings, Tap the ring down onto the points, and the inside and outside diameters can have the round-over applied. The downside is that there will be some small holes that will need to be filled afterwards, but they're pretty small. I used the same concept to cut a larger ring out of a piece of plywood.
tomp913 is offline
post #8 of 8 (permalink) Old 06-19-2016, 01:05 PM
this is worth a look...
http://www.routerforums.com/project-...ood-donut.html
Stick486 is offline
Incra CleanSweep Magnalock rings PhilBa Table-mounted Routing 23 05-08-2015 12:29 PM
adding rings to router plate Goblu Table-mounted Routing 10 05-14-2014 11:20 AM
routing rings to make a hollow cone brucegseidner Router Bits - Types and Usage 6 04-16-2010 11:56 PM
